[Swift-devel] folding/sequential-while/whatever and accessing data in files
Michael Wilde
wilde at mcs.anl.gov
Fri Sep 7 07:21:01 CDT 2007
The retval file would have a fixed format: multiple lines of "name
value". And it would only be used to return scalars or lists of
scalars: basically the same kinds of values that you can express as
swift literals. In this case:
error 21
perror "Threshold exceeded"
The variable "next" is a file or dataset and needs to be passed using
the current file mapping conventions.
With some thought, this could be generalized further to allow retval
expansion *within* a dataset, so any dataset could have an arbitrary
number of scalar values as fields along with file values.
- Mike
Ben Clifford wrote:
> On Fri, 7 Sep 2007, Michael Wilde wrote:
>> (int error, string perror, SomeFile next ) new_approximation (previous)
>> app RETVAL { ... }
>> The RETVAL keyword (caps mine) would signify that the app will produce a
>> RETVAL file and that the runtime system should use this file to set return
>> values as it indicates.
> That's very similar to execute-side mapping (which has been discussed) +
> application-side filecontent->value mapping.
> In the syntax example above, there's no place to specify the format in
> which the return value file is to be converted into the three swift values
> (int error, string perror, SomeFile next ).
