[Swift-devel] folding/sequential-while/whatever and accessing	data	in files
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Sep  7 07:03:41 CDT 2007
This problem is caused by the fact that swift functions can accept
integer values as arguments but cannot generate them as returns.
In the early Swift language discussions I advocated a means by which a
function could return an arbitrary number of integer values:
- in the app wrapper, one could designate a "value return file" that
would be created by the application
- the value return file would contain a simple list of names and value
- the values could be any swift expression composed of swift literals
(scalars or lists)
(int error, string perror, SomeFile next ) new_approximation (previous)
   app RETVAL { ... }
The RETVAL keyword (caps mine) would signify that the app will produce a
RETVAL file and that the runtime system should use this file to set
return values as it indicates.
- Mike
Ben Clifford wrote:
> One of the problems at the moment with implementing a
> fold/sequential-for/while loop is that I think a lot of the use cases want
> to make the termination condition be based on the output of the programs
> involved in the computation.
> At the moment, there isn't a way to get data from 'file space' into 'swift
> expression space' so  something like this[1]:
> iterate until error < 0.1 {
>   next = make_a_new_approximation(previous);
>   error = compute_error(next);
> fails in the present system because 'error' is a file-like entity (being
> the output of the compute_error application) rather than a
> swift-value-like entity (which is held in memory and can be used in
> expressions)
> I think mappers need to be made to address this.
> [1] syntax that i made up specifically for this email and that I do not
> advocate for use.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
