[Swift-devel] running MolDyn...
Ioan Raicu
iraicu at cs.uchicago.edu
Fri Sep 7 01:13:36 CDT 2007
Hi all,
I am trying to run MolDyn, and I am getting some exceptions early on in
the workflow.
> iraicu at viper:~/swift> swift -tc.file tc-uc.data -sites.file
> sites-uc-64.xml MolDyn-2-loops.swift
> Swift v0.2-dev
> RunID: 7i4yq1hr6uxb0
> pre_ch started
> 2007-09-07 00:59:14,181 WARN submitQueue.NonBlockingSubmit
> [pool-1-thread-1,notifyPreviousQueue:68] Warning: Task handler throws
> exception but does not set status
> java.lang.Exception: java.lang.NoSuchFieldError: DOCUMENT
> at
> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:92)
> at
> edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
> at
> edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
> at
> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
> at
> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
> at java.lang.Thread.run(Thread.java:534)
> Caused by: java.lang.NoSuchFieldError: DOCUMENT
> at
> org.globus.GenericPortal.stubs.Factory.bindings.FactoryPortTypeSOAPBindingStub._initOperationDesc1(FactoryPortTypeSOAPBindingStub.java:31)
> at
> org.globus.GenericPortal.stubs.Factory.bindings.FactoryPortTypeSOAPBindingStub.<clinit>(FactoryPortTypeSOAPBindingStub.java:20)
> at
> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceLocator.getFactoryPortTypePort(FactoryServiceLocator.java:55)
> at
> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator.getFactoryPortTypePort(FactoryServiceAddressingLocator.java:22)
> at
> org.globus.cog.abstraction.impl.execution.deef.ResourcePool.createResources(ResourcePool.java:117)
> at
> org.globus.cog.abstraction.impl.execution.deef.ResourcePool.instance(ResourcePool.java:77)
> at
> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler.doSubmit(JobSubmissionTaskHandler.java:146)
> at
> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:81)
> at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:54)
> at
> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:82)
> ... 5 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Note that the same exact workflow and settings work perfect on the same
machine, same credentials, just a different install.
> nefedova at viper:~/alamines> swift -tc.file tc-uc.data -sites.file
> Unable to find required classes (javax.activation.DataHandler and
> javax.mail.internet.MimeMultipart). Attachment support is disabled.
> Swift v0.2-dev
> RunID: 8cnditl4zu192
> pre_ch started
> pre_ch completed
> antch started
> antch started
> antch completed
> chrm started
> antch completed
> chrm started
Any hints on where to start looking for the problem?
Ioan
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dsl.cs.uchicago.edu/
