[Swift-devel] Re: latest Falkon code is in SVN!
Ioan Raicu iraicu at cs.uchicago.edu
Thu Sep 6 22:26:54 CDT 2007
You took my comment out of context.  I said:
> I would argue for having the default with no security enabled,
> especially between workers and the service.
So, again, this states that the default security level between service
and workers be without any security... I think it is OK (maybe even
preferred) to have the default security be enabled for the clients /
Falkon provider.  I still don't understand why you are saying that no
security implies "negligently broken", as that is what Condor and PBS do
as well.  The only entities injecting work into Falkon are the clients
(not the workers), and hence I agree that its important to protect
against clients by adding some default security.  Not protecting against
the workers might simply allow wholes in the system for denial of
service attacks, but I don't see how arbitrary code from anyone could
possibly be run if the single entry point into the service (the client
interface) is protected.
I really don't care what you set the defaults to, my only point and
argument was that I wanted to make things easiest on the end-users!
Ioan
Ben Clifford wrote:
> Giving software out to users that by default allows any person anywhere on
> the internet can execute arbitrary code as them seems negligently broken.
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070906/f2fbcc1b/attachment.html>
