[Swift-devel] Re: latest Falkon code is in SVN!
Ioan Raicu
iraicu at cs.uchicago.edu
Wed Sep 5 17:27:20 CDT 2007
Ben Clifford wrote:
> On Wed, 5 Sep 2007, Ioan Raicu wrote:
>> service on login node of some grid site
>> workers on compute nodes of the same grid site
> with each grid site likely beyond reasonable doubt to allow no external
> access to their worker nodes from anything other than the head node?
The workers only communicate with the service, so if they are running in
a LAN, the traffic is relatively OK. Remember that PBS, Condor, and the
likes, none of them use any form of security (with the exception of
maybe some rudimentary form of authentication), within a single cluster
environment. I was making the same assumption they are making.
> and
> with each person accessing the head node trusted?
Each person accessing the head node typically has an account on that
node, and is trusted to some degree.
> when your home directory
> is replaced with a file called sucker.txt and you have no problem with
> that, I'll agree with you.
You can enforce at the container what form of security is needed by
various functions of the service, including the job submission
function. You can use all sorts of authentication, encryption,
signature, etc... forms of security to ensure that whoever talks to the
Falkon service is trusted, but I still don't see why the workers would
need any more security that PBS/Condor in a LAN environment. Off
course, this changes 180 degrees once you go to a WAN and the traffic is
now crossing other networks.
From my point of view, its OK either way, but from my experience,
security is one of the biggest hurdles for new users of web services.
At any rate, we are only arguing what the defaults are, the important
thing is that we support a wide range of things, from no security to
full security!
Ioan
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dsl.cs.uchicago.edu/
