[Swift-devel] Re: latest Falkon code is in SVN!
Ioan Raicu
iraicu at cs.uchicago.edu
Wed Sep 5 17:05:30 CDT 2007
I don't know off the top of my head what might be wrong, I'll dig into
it later.
I would argue for having the default with no security enabled,
especially between workers and the service.
Remember that the typical scenario is:
client in the public internet
service on login node of some grid site
workers on compute nodes of the same grid site
I could understand if you want to have client to service security as a
default, but even that might cause more problems than its worth as most
new users will probably get stuck at that point.
I guess we can make the defaults anything we want, but we should clearly
outline in the readme files on how to change it.
Ioan
Ben Clifford wrote:
> On Fri, 31 Aug 2007, Ioan Raicu wrote:
>> Right, bu default, all the scripts are without security. To enable security,
>> one would have to modify 3 scripts (the service script -- remove -nosec
>> option, the worker script -- replace http with https, and the client script --
>> replace http with https), and update the etc/client-security-config.xml on the
>> worker and client accordingly with the relevant security parameters. It is
>> pretty straight forward, but I haven't got the chance to document it yet.
> I made this change:
> --- worker/etc/client-security-config.xml (revision 1191)
> +++ worker/etc/client-security-config.xml (working copy)
> @@ -1,8 +1,8 @@
> <?xml version="1.0" encoding="UTF-8"?>
> <!-- worker side -->
> <securityConfig xmlns="http://www.globus.org">
> -<!-- <authz value="self"/> -->
> - <authz value="none"/>
> + <authz value="self"/>
> +<!-- <authz value="none"/> -->
> <!--<GSITransport>
> <integrity/>
> <privacy/>
> but I get subject name errors when I run the worker, thusly:
> Caused by: org.globus.common.ChainedIOException: Authentication failed
> [Caused by: Operation unauthorized (Mechanism level: Authorization failed.
> Expected "/CN=host/localhost" target but received
> "/DC=org/DC=doegrids/OU=People/CN=Benjamin Clifford 418168")]
> I'm expecting everything to be using my subject name and there to be no
> host subject names anywhere.
> I can give more details about the other changes I've made if it would be
> useful.
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dsl.cs.uchicago.edu/
