[Swift-devel] detecting providers
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Sep  5 12:28:40 CDT 2007
On Wed, 2007-09-05 at 11:13 -0500, Mihael Hategan wrote:
> On Wed, 2007-09-05 at 16:06 +0000, Ben Clifford wrote:
> > On Wed, 5 Sep 2007, Mihael Hategan wrote:
> > > >  - it happily makes that directory and
> > > > deploys there. That's somewhat fragile behaviour given the intended use of
> > > > provider-deef.
> > > Also perfectly reasonable behavior in other cases.
> > provider-deef exists solely to interface falkon to swift. it is never
> > reasonable in normal usage for it to be deployed into a non-swift cog
> > deployment.
> Add a check in the build file then.
I added a warning to provider-deef/build.xml that gets printed and
pauses the build if there is no ${dist.dir}/bin/swift.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
