[Swift-devel] Cant get Falkon provider connected to Swift
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Sep  4 11:50:07 CDT 2007
On Tue, 2007-09-04 at 11:43 -0500, Michael Wilde wrote:
> Mihael Hategan wrote:
> ... the throttling
> > properties cannot be set from the command line.
> OK. So its intentional that some but not all properties can be set from
> the command line?  Is that by intent, or just that it takes extra coding
> to accept them, and its not been done yet?
It was done in order to keep the number of command line arguments, and
hence the size of what's printed when doing -help, to a sane value.
The choice of what to put in there was more or less dictated by what one
would be most likely to change from run to run, but then also things
closely related (having kickstart.enabled without
kickstart.always.transfer may have been a bit surprising).
> - Mike
