[Swift-devel] Cant get Falkon provider connected to Swift
Michael Wilde wilde at mcs.anl.gov
Tue Sep 4 11:18:21 CDT 2007
Excellent - exactly what I need. Can you put this in the users guide if
its not there already? (I may have missed it, if it is).
On a related note, I think I experienced surprising behavior in how the
swift command parses properties on the command line.  I had things in an
odd order, and it seemed to silently ignore throttling properties that
were placed after the swift file name, and not accept them when I moved
them where they belong, before the swift file name. They worked fine
when I put then in the properties file.
I need to capture the specific cases before I can file a bug on them,
but I had to move on.
Mike
Ben Clifford wrote:
> On Fri, 31 Aug 2007, Michael Wilde wrote:
>> Found the problem: I had been using symlinks from the swift etc dir to my
>> local sites and tc files, and set the links wrong when I switched to the
>> falkon-enabled build. Its running now - thanks.
> on a related note, you can configure the sites and tc files per
> user-account by making a .swift directory and putting property
> specifications in there, like this:
> $ cat ~train01/.swift/swift.properties
> sites.file=${user.home}/sites.xml
> tc.file=${user.home}/tc.data
