[Swift-devel] documenting sites.xml
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Sep  3 18:51:57 CDT 2007
On Mon, 2007-09-03 at 22:31 +0000, Ben Clifford wrote:
> On Mon, 3 Sep 2007, Mihael Hategan wrote:
> > But I'm not sure I agree with the last part of what you say. Ambiguities
> > cause errors (as in Java).
> this bit? :
Oh, I see. What you're saying is that an element without a namespace
will not default to a certain namespace even if there are no ambiguities
in that choice. Which I don't know exactly about XML, but in Karajan
that default will happen.
> >> defining an element in a different namespace can cause a non-labelled
> >> element to mean something different in karajan, which doesn't happen in
> >> XML Namespaces.
> There aren't ambiguities in XML namespace handling there. If a namespace
> prefix is used without being mapped somewhere (either the very small set
> of default mappings, or explicitly in an enclosing element) then the
> document is not valid.
Right.
