[Swift-devel] xml-intermediate-language branch
    Ben Clifford
    benc at hawaga.org.uk
    Mon Sep  3 10:31:37 CDT 2007
branches/xml-intermediate-language has the latest set of changes I want to
put in to make the XML intermediate language more xml-structured and less
ad-hoc.
for users, there shouldn't be immediate changes in already-working
behaviour; more stuff that intuitively should work will now work, removing
the need for some workarounds in programs where expressions don't work in
certain places - there are a number of bugs which this code will fix.
it seems to work OK in the testing I've done. I'm going to do more testing
on larger programs over the next few days and if that goes OK then put it
in trunk towards the end of this week.
if you test the code in xml-intermediate-language branch, you'll give me a
chance to fix your problems before you get screwed by them when I merge to
trunk. you can do this by following the usual build-from-SVN instructions
at http://www.ci.uchicago.edu/swift/downloads/index.php but replace the
checkout-swift svn command with:
(on one line)
svn co
https://svn.ci.uchicago.edu/svn/vdl2/branches/xml-intermediate-language
vdsk
(the difference being that the URL ends branches/xml-intermediate-language
rather than trunk)
