[Swift-devel] Re: latest Falkon code is in SVN!
    Ben Clifford
    benc at hawaga.org.uk
    Sat Sep  1 06:46:21 CDT 2007
Even better would be if the code that I assume came from Ioan's build
wasn't in the SVN in compiled form at all - I started playing at that
removing some of the precompiled .jar files in there, but something isn't
getting rebuilt properly so I need to play some more.
On Fri, 31 Aug 2007, Mihael Hategan wrote:
> Use javac -source 1.4 -target 1.4 when compiling.
> On Fri, 2007-08-31 at 10:53 +0000, Ben Clifford wrote:
> > When I run the client, I get this error, which looks like maybe you've got
> > some pre-compiled code that is compiled with something later than the 1.5
> > JDK that I use...
> > 2007-08-31 11:50:59,646 ERROR container.ServiceThread
> > [ServiceThread-2,run:297] Unexpected error during request processing
> > java.lang.UnsupportedClassVersionError: Bad version number in .class file
> >         at java.lang.ClassLoader.defineClass1(Native Method)
> >         at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
> >         at
> > java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
> >         at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
> >         at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
> >         at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
> >         at java.security.AccessController.doPrivileged(Native Method)
> >         at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
> >         at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
> >         at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
> >         at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
> >         at java.lang.Class.forName0(Native Method)
> >         at java.lang.Class.forName(Class.java:242)
> >         at org.apache.axis.utils.ClassUtils$2.run(ClassUtils.java:176)
> >         at org.apache.axis.utils.ClassUtils.loadClass(ClassUtils.java:160)
> >         at org.apache.axis.utils.ClassUtils.forName(ClassUtils.java:142)
> >         at
> > org.apache.axis.utils.cache.ClassCache.lookup(ClassCache.java:85)
> >         at
> > org.apache.axis.providers.java.JavaProvider.getServiceClass(JavaProvider.java:424)
> >         at
> > org.apache.axis.providers.java.JavaProvider.initServiceDesc(JavaProvider.java:457)
> >         at
> > org.apache.axis.handlers.soap.SOAPService.getInitializedServiceDesc(SOAPService.java:283)
> >         at
> > org.apache.axis.deployment.wsdd.WSDDService.makeNewInstance(WSDDService.java:487)
> >         at
> > org.apache.axis.deployment.wsdd.WSDDDeployableItem.getNewInstance(WSDDDeployableItem.java:274)
> >         at
> > org.apache.axis.deployment.wsdd.WSDDDeployableItem.getInstance(WSDDDeployableItem.java:260)
> >         at
> > org.apache.axis.deployment.wsdd.WSDDDeployment.getService(WSDDDeployment.java:478)
> >         at
> > org.apache.axis.configuration.DirProvider.getService(DirProvider.java:156)
> >         at org.apache.axis.AxisEngine.getService(AxisEngine.java:323)
> >         at
> > org.apache.axis.MessageContext.setTargetService(MessageContext.java:757)
> >         at
> > org.globus.wsrf.handlers.AddressingHandler.setTargetService(AddressingHandler.java:152)
> >         at
> > org.apache.axis.message.addressing.handler.AddressingHandler.processServerRequest(AddressingHandler.java:344)
> >         at
> > org.globus.wsrf.handlers.AddressingHandler.processServerRequest(AddressingHandler.java:77)
> >         at
> > org.apache.axis.message.addressing.handler.AddressingHandler.invoke(AddressingHandler.java:114)
> >         at
> > org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
> >         at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
> >         at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
> >         at org.apache.axis.server.AxisServer.invoke(AxisServer.java:248)
> >         at
> > org.globus.wsrf.container.ServiceThread.doPost(ServiceThread.java:664)
> >         at
> > org.globus.wsrf.container.ServiceThread.process(ServiceThread.java:382)
> >         at
> > org.globus.wsrf.container.ServiceThread.run(ServiceThread.java:291)
