[Swift-devel] Clustering and Temp Dirs with Swift
    Michael Wilde
    wilde at mcs.anl.gov
    Sun Oct 28 17:47:53 CDT 2007
We're gonna have a pretty serious party when we complete our first
10M-job workflow.  I look forward to this problem !!!
:) Mike
On 10/28/07 5:34 PM, Mihael Hategan wrote:
>> Well lg(37^9) =~ 14, so you need about 14 digits to cover the same range
>> of values:
>> 00000000000000/angle4-00000000000001-kickstart.xml
> Although that's silly. We'll never have more than 10 million jobs of a
> kind (pretty much like 640K should be enough for everybody).
>>> 000000/angle4-00000002-kickstart.xml
>>> 000000/angle4-00000099-kickstart.xml
>>> 000020/angle4-00002076-kickstart.xml
>>> etc.
>>> This makes splitting based on powers of 10 (or 26 or 36) trivial. Other
>>> splits can be done with mod() functions.
>>> Can we start heading in this or some similar direction?
>>> We need to coordinate a plan for this, I suspect, to make Andrew's
>>> workflows perform acceptably.
>>> - Mike
>>> On 10/27/07 2:08 PM, Ben Clifford wrote:
>>>> On Sat, 27 Oct 2007, Mihael Hategan wrote:
>>>>> Quickly before I leave the house:
>>>>> Perhaps we could try copying to local FS instead of linking from shared
>>>>> dir and hence running the jobs on the local FS.
>>>> Maybe. I'd be suspicious that doesn't reduce access to the directory too
>>>> much.
>>>> I think the directories where there are lots of files being read/written
>>>> by lots of hosts are:
>>>> the top directory (one job directory per job)
>>>> the info directory
>>>> the kickstart directory
>>>> the file cache
>>>> In the case where directories get too many files in them because of
>>>> directory size constraints, its common to split that directory into many
>>>> smaller directories (eg. how squid caching, or git object storage works).
>>>> eg, given a file fubar.txt store it in fu/fubar.txt, with 'fu' being some
>>>> short hash of the filename (with the hash here being 'extract the first
>>>> two characters).
>>>> Pretty much I think Andrew wanted to do that for his data files anyway,
>>>> which would then reflect in the layout of the data cache directory
>>>> structure.
>>>> For job directories, it may not be too hard to split the big directories
>>>> into smaller ones. There will still be write-lock conflicts, but this
>>>> might mean the contention for each directories write-lock is lower.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
