[Swift-devel] Clustering and Temp Dirs with Swift
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Oct 28 17:27:53 CDT 2007
On Sun, 2007-10-28 at 17:15 -0500, Michael Wilde wrote:
> If these were numeric patterns,
the string would be longer.
> it would be easy to eg put 100 files per
> dir by taking say the leftmost 6 characters and making that a dirname
> within which the rightmost 2 chars would vary:
With alpha-numeric ones, it's fairly easy to put 37 files per dir.
Anyway. It doesn't matter. Either way. The problem isn't what exact
numbering base we're using, but how exactly we put them in
subdirectories.
> tlivaj/angle4-tlivajim-kickstart.xml
> tlivaj/angle4-tlivajin-kickstart.xml
> tlivaj/angle4-tlivajio-kickstart.xml
> tlivaj/angle4-tlivajip-kickstart.xml
> tlivaj/angle4-tlivajiq-kickstart.xml
> but easier on my eyes would be:
> 000000/angle4-00000001-kickstart.xml
Well lg(37^9) =~ 14, so you need about 14 digits to cover the same range
of values:
00000000000000/angle4-00000000000001-kickstart.xml
> 000000/angle4-00000002-kickstart.xml
> 000000/angle4-00000099-kickstart.xml
> 000020/angle4-00002076-kickstart.xml
> etc.
> This makes splitting based on powers of 10 (or 26 or 36) trivial. Other
> splits can be done with mod() functions.
> Can we start heading in this or some similar direction?
> We need to coordinate a plan for this, I suspect, to make Andrew's
> workflows perform acceptably.
> - Mike
> On 10/27/07 2:08 PM, Ben Clifford wrote:
> > On Sat, 27 Oct 2007, Mihael Hategan wrote:
> >> Quickly before I leave the house:
> >> Perhaps we could try copying to local FS instead of linking from shared
> >> dir and hence running the jobs on the local FS.
> > Maybe. I'd be suspicious that doesn't reduce access to the directory too
> > much.
> > I think the directories where there are lots of files being read/written
> > by lots of hosts are:
> > the top directory (one job directory per job)
> > the info directory
> > the kickstart directory
> > the file cache
> > In the case where directories get too many files in them because of
> > directory size constraints, its common to split that directory into many
> > smaller directories (eg. how squid caching, or git object storage works).
> > eg, given a file fubar.txt store it in fu/fubar.txt, with 'fu' being some
> > short hash of the filename (with the hash here being 'extract the first
> > two characters).
> > Pretty much I think Andrew wanted to do that for his data files anyway,
> > which would then reflect in the layout of the data cache directory
> > structure.
> > For job directories, it may not be too hard to split the big directories
> > into smaller ones. There will still be write-lock conflicts, but this
> > might mean the contention for each directories write-lock is lower.
