[Swift-devel] Clustering and Temp Dirs with Swift
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Oct 26 16:31:30 CDT 2007
On Fri, 2007-10-26 at 16:23 -0500, Ioan Raicu wrote:
> Hi,
> Andrew Robert Jamieson wrote:
> > Ioan,
> >   Thanks for the explaination.  It seems like you characterized what
> > is going on pretty well.
> > One question I have is, does this case occur only for situations in
> > which it is in the same directory or is it anywhere at any given time
> > in the shared GPFS?
> I don't know, but as far as I can tell, Swift will create these temp
> scratch directories per job in the same subdirectory (Mihael or Ben,
> please correct me if I am wrong on this).  I have seen this behavior for
> certain in this case, but am not sure if things get better if you were
> to work in completely separate parts of the filesystem.
> > Furthermore, why can't the short lived directory live on the local
> > node's /tmp/* somewhere?  I have wrapped all my programs to ensure
> > that things are ONLY executed on the local node directories to
> > specifically aviod this type of problem. Now Swift is making that
> > effort irrelevant it seems.
Right. And Swift has an inefficient implementation there which needs to
be fixed.
> They could, with some modifications to the wrapper script.  Or with some
> higher level logic that manages the data on the local disk and moves it
> in and out from and to the shared file system.   Your short term
> solution would probably be the first option, changing the wrapper script
> to support local disk usage.  Maybe there are other solutions as well.
> Ioan
> > Does this seem reasonable?
> > Thanks,
> > Andrew
> > On Fri, 26 Oct 2007, Ioan Raicu wrote:
> >> I am not sure what configuration exists on TP, but on the TeraGrid
> >> ANL/UC cluster, with 8 servers behind GPFS, the wrapper script
> >> performance (create dir, create symbolic links, remove directory...
> >> all on GPFS) is anywhere between 20~40 / sec, depending on how many
> >> nodes you have doing this concurrently.  The throughput increases
> >> first as you add nodes, but then decreases down to about 20/sec with
> >> 20~30+ nodes.  What this means is that even if you bundle jobs up,
> >> you will not get anything better than this, throughput wise,
> >> regardless of how short the jobs are.  Now, if TP has less than 8
> >> servers, its likely that the throughput it can sustain is even lower,
> >> and if you push it over the edge, even to the point of thrashing
> >> where the throughput can be extremely small.   I don't have any
> >> suggestions of how you can get around this, with the exception of
> >> making your job sizes larger on average, and hence have fewer jobs
> >> over the same period of time.
> >> Ioan
> >>> I am kind of at a stand still for getting anything done on TP right
> >>> now with this problem. Are there any suggestions to overcome this
> >>> for the time being?
> >>> On Fri, 26 Oct 2007, Andrew Robert Jamieson wrote:
> >>>> Hello all,
> >>>>  I am encountering the following problem on Teraport.  I submit a
> >>>> clustered swift WF which should amount to something on the order of
> >>>> 850x3 individual jobs total. I have clustered the jobs because they
> >>>> are very fast (somewhere around 20 sec to 1 min long).  When I
> >>>> submit the WF on TP things start out fantastic, I get 10s of output
> >>>> files in a matter of seconds and nodes would start and finish
> >>>> clustered batches in a matter of minutes or less. However, after
> >>>> waiting about 3-5 mins, when clustered jobs are begin to line up in
> >>>> the queue and more start running at the same time, things start to
> >>>> slow down to a trickle in terms of output.
> >>>> One thing I noticed is when I try a simply ls on TP in the swift
> >>>> temp running directory where the temp job dirs are created and
> >>>> destroyed, it take a very long time.  And when it is done only five
> >>>> or so things are in the dir. (this is the dir with "info
> >>>> kickstart  shared  status wrapper.log" in it).  What I think is
> >>>> happening is that TP's filesystem cant handle this extremely rapid
> >>>> creation/destruction of directories in that shared location. From
> >>>> what I have been told these temp dirs come and go as long as the
> >>>> job runs successfully.
> >>>> What I am wondering is if there is anyway to move that dir to the
> >>>> local node tmp diretory not the shared file system, while it is
> >>>> running and if something fails then have it sent to the appropriate
> >>>> place.
> >>>> Or, if another layer of temp dir wrapping could be applied with
> >>>> labeld perhaps with respect to the clustered job grouping and not
> >>>> simply the individual jobs (since there are thousands being
> >>>> computed at once).
> >>>> That these things would only be generated/deleted every 5 mins or
> >>>> 10 mins (if clustered properly on my part) instead of one event
> >>>> every milli second or what have you.
> >>>> I don't know which solution is feasible or if any are at all, but
> >>>> this seems to be a major problem for my WFs.  In general it is
> >>>> never good to have a million things coming and going on a shared
> >>>> file system in one place, from my experience at least.
> >>>> Thanks,
> >>>> Andrew
> >>>> _______________________________________________
> >>>> Swift-devel mailing list
> >>>> Swift-devel at ci.uchicago.edu
> >>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> >> Ioan Raicu
> >> Ph.D. Student
> >> Distributed Systems Laboratory
> >> Computer Science Department
> >> University of Chicago
> >> 1100 E. 58th Street, Ryerson Hall
> >> Chicago, IL 60637
> >> Email: iraicu at cs.uchicago.edu
> >> Web:   http://www.cs.uchicago.edu/~iraicu
> >>      http://dsl.cs.uchicago.edu/
