[Swift-devel] Clustering and Temp Dirs with Swift
Veronika Nefedova nefedova at mcs.anl.gov
Fri Oct 26 16:17:01 CDT 2007
Andrew,
I am not sure if I understand you correctly. If you want to have all
your working directories to be on a local disk, why don't you specify
that local directory in you sites.xml file as a 'workddirectory'? All
temp dirs will be relative to that workdirectory from the sites.xml
file.
Nika
On Oct 26, 2007, at 4:05 PM, Andrew Robert Jamieson wrote:
> Ioan,
>   Thanks for the explaination.  It seems like you characterized
> what is going on pretty well.
> One question I have is, does this case occur only for situations in
> which it is in the same directory or is it anywhere at any given
> time in the shared GPFS?
> Furthermore, why can't the short lived directory live on the local
> node's /tmp/* somewhere?  I have wrapped all my programs to ensure
> that things are ONLY executed on the local node directories to
> specifically aviod this type of problem. Now Swift is making that
> effort irrelevant it seems.
> Does this seem reasonable?
> Thanks,
> Andrew
> On Fri, 26 Oct 2007, Ioan Raicu wrote:
>> I am not sure what configuration exists on TP, but on the TeraGrid
>> ANL/UC cluster, with 8 servers behind GPFS, the wrapper script
>> performance (create dir, create symbolic links, remove
>> directory... all on GPFS) is anywhere between 20~40 / sec,
>> depending on how many nodes you have doing this concurrently.  The
>> throughput increases first as you add nodes, but then decreases
>> down to about 20/sec with 20~30+ nodes.  What this means is that
>> even if you bundle jobs up, you will not get anything better than
>> this, throughput wise, regardless of how short the jobs are.  Now,
>> if TP has less than 8 servers, its likely that the throughput it
>> can sustain is even lower, and if you push it over the edge, even
>> to the point of thrashing where the throughput can be extremely
>> small.   I don't have any suggestions of how you can get around
>> this, with the exception of making your job sizes larger on
>> average, and hence have fewer jobs over the same period of time.
>> Ioan
>>> I am kind of at a stand still for getting anything done on TP
>>> right now with this problem. Are there any suggestions to
>>> overcome this for the time being?
>>> On Fri, 26 Oct 2007, Andrew Robert Jamieson wrote:
>>>> Hello all,
>>>>  I am encountering the following problem on Teraport.  I submit
>>>> a clustered swift WF which should amount to something on the
>>>> order of 850x3 individual jobs total. I have clustered the jobs
>>>> because they are very fast (somewhere around 20 sec to 1 min
>>>> long).  When I submit the WF on TP things start out fantastic, I
>>>> get 10s of output files in a matter of seconds and nodes would
>>>> start and finish clustered batches in a matter of minutes or
>>>> less. However, after waiting about 3-5 mins, when clustered jobs
>>>> are begin to line up in the queue and more start running at the
>>>> same time, things start to slow down to a trickle in terms of
>>>> output.
>>>> One thing I noticed is when I try a simply ls on TP in the swift
>>>> temp running directory where the temp job dirs are created and
>>>> destroyed, it take a very long time.  And when it is done only
>>>> five or so things are in the dir. (this is the dir with "info
>>>> kickstart  shared  status wrapper.log" in it).  What I think is
>>>> happening is that TP's filesystem cant handle this extremely
>>>> rapid creation/destruction of directories in that shared
>>>> location. From what I have been told these temp dirs come and go
>>>> as long as the job runs successfully.
>>>> What I am wondering is if there is anyway to move that dir to
>>>> the local node tmp diretory not the shared file system, while it
>>>> is running and if something fails then have it sent to the
>>>> appropriate place.
>>>> Or, if another layer of temp dir wrapping could be applied with
>>>> labeld perhaps with respect to the clustered job grouping and
>>>> not simply the individual jobs (since there are thousands being
>>>> computed at once).
>>>> That these things would only be generated/deleted every 5 mins
>>>> or 10 mins (if clustered properly on my part) instead of one
>>>> event every milli second or what have you.
>>>> I don't know which solution is feasible or if any are at all,
>>>> but this seems to be a major problem for my WFs.  In general it
>>>> is never good to have a million things coming and going on a
>>>> shared file system in one place, from my experience at least.
>>>> Thanks,
>>>> Andrew
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Ioan Raicu
>> Ph.D. Student
>> Distributed Systems Laboratory
>> Computer Science Department
>> University of Chicago
>> 1100 E. 58th Street, Ryerson Hall
>> Chicago, IL 60637
>> Email: iraicu at cs.uchicago.edu
>> Web:   http://www.cs.uchicago.edu/~iraicu
>>      http://dsl.cs.uchicago.edu/
