[Swift-devel] Strange Problem with TG-UCANL
    Andrew Robert Jamieson
    andrewj at uchicago.edu
    Thu Oct 25 10:50:33 CDT 2007
Any thoughts on why this would happen on a simple "hello world"
(see below)
Andrew
andrewj at tg-viz-login1:~/CADGrid/Swifty/vdsk-0.3-dev/examples/vdsk> swift
-debug -tc.file ~/CADGrid/Swifty/UCANL-tc.data -sites.file
~/.swift/sites.xml first.swift
Recompilation suppressed.
Using sites  /home/andrewj/.swift/sites.xml
Using tc.data: /home/andrewj/CADGrid/Swifty/UCANL-tc.data
Swift v0.3-dev r1339
RunID: 20071025-1044-zo4kzfjg
echo started
START thread=0 tr=echo
START host=UCANL - Initializing shared directory
Task(type=FILE_OPERATION, identity=urn:0-1193327080146) setting status to
Active
Completed
Task(type=FILE_TRANSFER, identity=urn:0-1193327080149) setting status to
Submitted
Active
Completed
Task(type=FILE_TRANSFER, identity=urn:0-1193327080153) setting status to
Submitted
Active
Completed
Task(type=FILE_OPERATION, identity=urn:0-1193327080156) setting status to
Active
Completed
Task(type=FILE_OPERATION, identity=urn:0-1193327080158) setting status to
Active
Completed
Task(type=FILE_OPERATION, identity=urn:0-1193327080160) setting status to
Active
Completed
END host=UCANL - Done initializing shared directory
THREAD_ASSOCIATION jobid=echo-0gj1k5ji thread=0 host=UCANL
START jobid=echo-0gj1k5ji host=UCANL - Initializing directory structure
START path= dir=first-20071025-1044-zo4kzfjg/shared - Creating directory
structure
Task(type=FILE_OPERATION, identity=urn:0-1193327080162) setting status to
Active
Completed
END jobid=echo-0gj1k5ji - Done initializing directory structure
START jobid=echo-0gj1k5ji - Staging in files
END jobid=echo-0gj1k5ji - Staging in finished
JOB_START jobid=echo-0gj1k5ji tr=echo arguments=[Hello, world!]
tmpdir=first-20071025-1044-zo4kzfjg/echo-0gj1k5ji host=UCANL
Task(type=JOB_SUBMISSION, identity=urn:0-1193327080164) setting status to
Submitted
Active
Completed
Task(type=FILE_OPERATION, identity=urn:0-1193327080166) setting status to
Active
Failed org.globus.cog.abstraction.impl.file.FileResourceException: Cannot
delete
/disks/scratchgpfs1/andrewj/first-20071025-1044-zo4kzfjg/status/echo-0gj1k5ji-success
Task(type=FILE_OPERATION, identity=urn:0-1193327080168) setting status to
Active
Completed
NO_STATUS_FILE jobid=echo-0gj1k5ji - Both status files are missing
APPLICATION_EXCEPTION jobid=echo-0gj1k5ji - Application exception: No
status file was found. Check the shared filesystem on UCANL
         sys:throw @ vdl-int.k, line: 96
         sys:else @ vdl-int.k, line: 94
         sys:if @ vdl-int.k, line: 82
         sys:try @ vdl-int.k, line: 70
         vdl:checkjobstatus @ vdl-int.k, line: 379
         sys:sequential @ vdl-int.k, line: 355
         sys:try @ vdl-int.k, line: 354
         task:allocatehost @ vdl-int.k, line: 336
         vdl:execute2 @ execute-default.k, line: 23
         sys:restartonerror @ execute-default.k, line: 21
         sys:sequential @ execute-default.k, line: 19
         sys:try @ execute-default.k, line: 18
         sys:if @ execute-default.k, line: 17
         sys:then @ execute-default.k, line: 16
         sys:if @ execute-default.k, line: 15
         vdl:execute @ first.kml, line: 16
         greeting @ first.kml, line: 43
         vdl:mainp @ first.kml, line: 42
         mainp @ vdl.k, line: 148
         vdl:mains @ first.kml, line: 41
         rlog:restartlog @ first.kml, line: 39
         kernel:project @ first.kml, line: 2
Task(type=FILE_TRANSFER, identity=urn:0-1193327080170) setting status to
Submitted
Active
Failed Exception in getFile
Task(type=FILE_OPERATION, identity=urn:0-1193327080173) setting status to
Active
Completed
Task(type=FILE_TRANSFER, identity=urn:0-1193327080176) setting status to
Submitted
Active
Task(type=FILE_OPERATION, identity=urn:0-1193327080179) setting status to
Active
Completed
THREAD_ASSOCIATION jobid=echo-1gj1k5ji thread=0 host=UCANL
START jobid=echo-1gj1k5ji host=UCANL - Initializing directory structure
END jobid=echo-1gj1k5ji - Done initializing directory structure
START jobid=echo-1gj1k5ji - Staging in files
END jobid=echo-1gj1k5ji - Staging in finished
JOB_START jobid=echo-1gj1k5ji tr=echo arguments=[Hello, world!]
tmpdir=first-20071025-1044-zo4kzfjg/echo-1gj1k5ji host=UCANL
Task(type=JOB_SUBMISSION, identity=urn:0-1193327080183) setting status to
Submitted
Active
Completed
Task(type=FILE_OPERATION, identity=urn:0-1193327080185) setting status to
Active
delete
/disks/scratchgpfs1/andrewj/first-20071025-1044-zo4kzfjg/status/echo-1gj1k5ji-success
Task(type=FILE_OPERATION, identity=urn:0-1193327080187) setting status to
Active
Completed
NO_STATUS_FILE jobid=echo-1gj1k5ji - Both status files are missing
APPLICATION_EXCEPTION jobid=echo-1gj1k5ji - Application exception: No
Task(type=FILE_TRANSFER, identity=urn:0-1193327080189) setting status to
Submitted
Active
Task(type=FILE_OPERATION, identity=urn:0-1193327080192) setting status to
Active
Completed
Task(type=FILE_TRANSFER, identity=urn:0-1193327080195) setting status to
Submitted
Active
Task(type=FILE_OPERATION, identity=urn:0-1193327080198) setting status to
Active
Completed
THREAD_ASSOCIATION jobid=echo-2gj1k5ji thread=0 host=UCANL
START jobid=echo-2gj1k5ji host=UCANL - Initializing directory structure
END jobid=echo-2gj1k5ji - Done initializing directory structure
START jobid=echo-2gj1k5ji - Staging in files
END jobid=echo-2gj1k5ji - Staging in finished
JOB_START jobid=echo-2gj1k5ji tr=echo arguments=[Hello, world!]
tmpdir=first-20071025-1044-zo4kzfjg/echo-2gj1k5ji host=UCANL
Task(type=JOB_SUBMISSION, identity=urn:0-1193327080202) setting status to
Submitted
Active
Completed
Task(type=FILE_OPERATION, identity=urn:0-1193327080204) setting status to
Active
Completed
SUCCESS jobid=echo-2gj1k5ji - Success file found
JOB_END jobid=echo-2gj1k5ji
START jobid=echo-2gj1k5ji - Staging out files
FILE_STAGE_OUT_START srcname=hello.txt
srcdir=first-20071025-1044-zo4kzfjg/shared/ srchost=UCANL destdir=
desthost=localhost provider=file
Task(type=FILE_OPERATION, identity=urn:0-1-1193327080206) setting status
to Active
to Completed
Task(type=FILE_TRANSFER, identity=urn:0-1-1193327080209) setting status to
Submitted
Active
Completed
FILE_STAGE_OUT_END srcname=hello.txt
Task(type=FILE_OPERATION, identity=urn:0-1-1193327080213) setting status
to Active
to Completed
END jobid=echo-2gj1k5ji - Staging out finished
echo completed
END_SUCCESS thread=0 tr=echo
START cleanups=[[first-20071025-1044-zo4kzfjg, UCANL]]
START dir=first-20071025-1044-zo4kzfjg host=UCANL
Task(type=JOB_SUBMISSION, identity=urn:0-1-1193327080216) setting status
to Submitted
to Completed
END dir=first-20071025-1044-zo4kzfjg host=UCANL
Swift finished - workflow had no errors
