[Swift-devel] data dependency guts
Michael Wilde
wilde at mcs.anl.gov
Wed Oct 10 17:29:35 CDT 2007
This is great info and Im still digesting it. Lets put it in a design
doc/page.
My first question is, regarding:
type file;
string s;
file f <single_file_mapper;file=s>;
s="foo";
Why cant this execute as if it were:
type file;
string s;
string f;
file=s;
s="foo";
I havent tried this yet, but in this case where f is a string rather
than file, swift would swift not sort out the data dependencies correctly?
The point is that mapping a file to a var is (or should/could be) very
much like initializing it.
regular vars have a type, a state (set/unset) and a value (if set);
file vars have a type, a state, a mapping, and a value.
The problem we have is both that file vars can only get their mapping in
a specific and limited way (through the <> declaration) and that this
mapping is not processed like any other swift expression (else it would
sort out the data flow correctly).
- Mike
On 10/10/07 5:06 PM, Ben Clifford wrote:
> At present, procedures and the main program are compiled to karajan code
> in two sections:
> * a declaration section
> * a statements section
> When a variable is declared, the kml code to make a karjan-level variable
> of the same name goes into the declaration section.
> Non-variable declaration code such as procedure calls or foreach loops go
> into the statements sections.
> Statements which set the value of variables appear in either the
> declaration section or the statements section, depending on their
> particular nature (for example, initialisation with expressions goes into
> the declaration section; initialisation with the return value of a
> procedure goes into the statements section).
> When this code is executed in karajan, first all the declarations are
> executed in sequence; then when all of those have finished, all of the
> statements are executed in parallel.
> If there are data dependencies, those will cause an ordering of the
> parallel statements in the statements block such that they don't actually
> execute in parallel, but are instead ordered by their data dependencies.
> That data dependency management in the statements section happens through
> the variables which are declared in the declarations section; when a
> declaration happens for a variable that doesn't have an initial value,
> that variable instead stores (amongst other things) an indication that it
> doesn't have a value (yet).
> Data dependency ordering of execution will only happen for statements in
> the statements section, not for anything in the declaration section.
> Mapper declarations also go in the declaration section. This means that
> their parameters do not participate in data dependency ordering.
> For example, you can't say this in the present (r1339) implementation:
> type file;
> string s;
> s="foo";
> This will fail (with an exception) because some initialisation will happen
> (or rather will attempt to happen) for f strictly before s is given a
> value (by strictly before, I mean always before, rather than a race to
> perhaps be before, perhaps after).
> There does not seem to be an immediately correct easy solution to this.
> One idea I have toyed with a little is doing more compile-time analysis of
> dataflow to generalise the 'declaration block -> statement block'
> serialisation, so that there is more serialised/parallel specification in
> the kml.
> Another is to put add a new concept of 'not mapped yet' to datasets; and
> allow the same dataflow-ordered execution model that populates values also
> be used to populate mapping configuration.
