[Swift-devel] readData
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Oct 10 11:28:17 CDT 2007
On 10/10/07 10:38 AM, Ben Clifford wrote:
> You may not be experiencing a race in readData.
Indeed.  I replaced print() with a function call and it works fine now.
> You may instead be experiencing a race in the implementation of print. It
> will print out what it knows about its parameters at the time that its
> encountered. Sometimes, that is the value (if the value has been set);
> sometimes its the other output you see, a description of the dataset
> indicating that it doesn't have a value yet.
> Its probably desirable for print to wait for its parameter to be closed.
Right - it should behave like any other function imo. Is that readily
fixable?
- Mike
> On Wed, 10 Oct 2007, Michael Wilde wrote:
>> OK, what seems to be happening is that a simple script using readdata fails
>> occasionally. Ie, some kind of race.
>> Heres the test script and data file:
>> -- script t30.swift:
>> type circle {
>>         int x;
>>         int y;
>> circle ca;
>> ca = readdata("d1");
>> print(ca.x," ",ca.y);
>> -- and file d1:
>> x             y
>> 1             10
>> 2             20
>> Running this 6 times, I got 4 successes and 2 failures (of which 5 runs are
>> shown here with a few extraneous intevening commands removed):
>> RunID: 20071010-1024-1h41p37d
>> 1 10
>> $ swift -sites.file ./sites.xml -tc.file ./tc.data t30.swift
>> Swift v0.3-dev r1339
>> RunID: 20071010-1024-kiimrf7f
>> 1 10
>> RunID: 20071010-1024-49v2bnzb
>> 1 10
>> RunID: 20071010-1025-m0qmf0hc
>> 1 10
>> RunID: 20071010-1025-cicpxii8
>> org.griphyn.vdl.mapping.DataNode with no value at dataset=ca path=.x
>> org.griphyn.vdl.mapping.DataNode with no value at dataset=ca path=.y
>> On 10/10/07 10:12 AM, Michael Wilde wrote:
>>> Thats not what I encountered when I tested (which surprised me).
>>> I will restest and see what confused me (or my code).
>>> - Mike
>>> On 10/10/07 9:31 AM, Mihael Hategan wrote:
>>>> On Wed, 2007-10-10 at 09:00 -0500, Michael Wilde wrote:
>>>>> Mihael, all - readdata() works great, and I think gives Andrew exactly
>>>>> what he asked for.
>>>>> I updated the example parameter-sweep loop to use readdata to grab the
>>>>> multi-column input file.
>>>>> One note: as far as I can tell, you use the conventions the data columns
>>>>> must be exactly 16 characters wide, space separated. Is that correct? (I
>>>>> assume we'll generalize this time permits).
>>>> No. They must be horizontal-whitespace separated. The 16 characters wide
>>>> restriction does not exist. The following is valid:
>>>> a b           c                        d
>>>> 1 2 3 4
>>>> 5             6 7 8
>>>> 9                        10        11        12
>>>>> Here's the new example, Andrew.
>>>>> - Mike
>>>>> type file;
>>>>> // Simulate encapsulating an app's parameters as a struct
>>>>> type params {
>>>>>    int x;
>>>>>    int y;
>>>>>    float r;
>>>>>    boolean b;
>>>>>    string infilename;
>>>>>    string outfilename;
>>>>> // Simulate an app
>>>>> myapp(params p, file infile, file outfile )
>>>>>      app {
>>>>>          db "pecho:" p.x p.y p.r p.b p.infilename p.outfilename  @infile
>>>>> @outfile ;
>>>>> // Loop over the parameter array, calling app in parallel
>>>>> doall(params plist[])
>>>>>    foreach pval,j in plist {
>>>>>      // convert filename string to mapped file reference
>>>>>      file infile <single_file_mapper;file=pval.infilename>;
>>>>>      file outfile <single_file_mapper;file=pval.outfilename>;
>>>>>      // Call the application
>>>>>      myapp(pval,infile, outfile);
>>>>> // Main
>>>>> params plist[];
>>>>> plist = readdata("parameters");
>>>>> doall(plist);
>>>>> // Data File "parameters" follows.  Data files listed in it must exist.
>>>>> // each line is greater than 80 bytes and is only wrapped here by email
>>>>> // (actual files attached)
>>>>> x               y               r               b infilename
>>>>> outfilename
>>>>> 1               2               1.234           1 inf001.data
>>>>> outf001.data
>>>>> 3               4               5.678           0 inf002.data
>>>>> outf002.data
>>>>> On 10/10/07 5:23 AM, Ben Clifford wrote:
>>>>>> Mihael added the below language construct to the language the other
>>>>>> day.
>>>>>> This might be useful where the csv_mapper was being used before to
>>>>>> read in non-file data.
>>>>>> Its in the SVN.
>>>>>> There's a new function: readData. It's not an @function, so don't use
>>>>>> it
>>>>>> that way because it won't work (it needs to know what variable it
>>>>>> assigns to, so that it knows how to interpret the contents of the
>>>>>> file).
>>>>>> It can read primitive things, arrays of primitive things, structs and
>>>>>> arrays of structs.
>>>>>> It can either take a file or a string as a parameter, although I
>>>>>> recommend the former since it can deal with data dependencies.
>>>>>> For example usage, see tests/language-behaviour/readData.swift.
>>>>>> Here's a short preview:
>>>>>> type circle {
>>>>>>         int x;
>>>>>>         int y;
>>>>>>         float r;
>>>>>>         string name;
>>>>>> circle ca[];
>>>>>> ca = readData("readData.circleArray.in");
>>>>>> readData.circleArray.in:
>>>>>> x               y               r               name
>>>>>> 1               1               5               CircleOne
>>>>>> 2               2               7               CircleTwo
>>>>>> It doesn't deal with spaces in strings in the CSV format for now, but
>>>>>> it's a start.
>>>>>> Mihael
>>>>> plain text document attachment (t5g.swift)
>>>>> type file;
>>>>> type params {
>>>>>   int x;
>>>>>   int y;
>>>>>   float r;
>>>>>   boolean b;
>>>>>   string infilename;
>>>>>   string outfilename;
>>>>> // Simulate an app
>>>>> {      app {          db "pecho:" p.x p.y p.r p.b p.infilename
>>>>> p.outfilename  @infile @outfile ;
>>>>>     }  } // Loop over the parameter array, calling app in parallel
>>>>> // Main
>>>>> params plist[];
>>>>> doall(plist);
>>>>> plain text document attachment (parameters)
>>>>> x               y               r               b
>>>>> infilename      outfilename
>>>>> 1               2               1.234           1
>>>>> inf001.data     outf001.data
>>>>> 3               4               5.678           0
>>>>> inf002.data     outf002.data
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
