[Swift-devel] readData
Michael Wilde wilde at mcs.anl.gov
Wed Oct 10 10:34:09 CDT 2007
OK, what seems to be happening is that a simple script using readdata
fails occasionally. Ie, some kind of race.
Heres the test script and data file:
-- script t30.swift:
type circle {
         int x;
         int y;
circle ca;
ca = readdata("d1");
print(ca.x," ",ca.y);
-- and file d1:
x             y
1             10
2             20
Running this 6 times, I got 4 successes and 2 failures (of which 5 runs
are shown here with a few extraneous intevening commands removed):
RunID: 20071010-1024-1h41p37d
1 10
$ swift -sites.file ./sites.xml -tc.file ./tc.data t30.swift
Swift v0.3-dev r1339
RunID: 20071010-1024-kiimrf7f
1 10
RunID: 20071010-1024-49v2bnzb
1 10
RunID: 20071010-1025-m0qmf0hc
1 10
RunID: 20071010-1025-cicpxii8
org.griphyn.vdl.mapping.DataNode with no value at dataset=ca path=.x
org.griphyn.vdl.mapping.DataNode with no value at dataset=ca path=.y
On 10/10/07 10:12 AM, Michael Wilde wrote:
> Thats not what I encountered when I tested (which surprised me).
> I will restest and see what confused me (or my code).
> - Mike
> On 10/10/07 9:31 AM, Mihael Hategan wrote:
>> On Wed, 2007-10-10 at 09:00 -0500, Michael Wilde wrote:
>>> Mihael, all - readdata() works great, and I think gives Andrew
>>> exactly what he asked for.
>>> I updated the example parameter-sweep loop to use readdata to grab
>>> the multi-column input file.
>>> One note: as far as I can tell, you use the conventions the data
>>> columns must be exactly 16 characters wide, space separated. Is that
>>> correct? (I assume we'll generalize this time permits).
>> No. They must be horizontal-whitespace separated. The 16 characters wide
>> restriction does not exist. The following is valid:
>> a b           c                        d
>> 1 2 3 4
>> 5             6 7 8
>> 9                        10        11        12
>>> Here's the new example, Andrew.
>>> - Mike
>>> type file;
>>> // Simulate encapsulating an app's parameters as a struct
>>> type params {
>>>    int x;
>>>    int y;
>>>    float r;
>>>    boolean b;
>>>    string infilename;
>>>    string outfilename;
>>> // Simulate an app
>>> myapp(params p, file infile, file outfile )
>>>      app {
>>>          db "pecho:" p.x p.y p.r p.b p.infilename p.outfilename
>>> @infile @outfile ;
>>> // Loop over the parameter array, calling app in parallel
>>> doall(params plist[])
>>>    foreach pval,j in plist {
>>>      // convert filename string to mapped file reference
>>>      file infile <single_file_mapper;file=pval.infilename>;
>>>      file outfile <single_file_mapper;file=pval.outfilename>;
>>>      // Call the application
>>>      myapp(pval,infile, outfile);
>>> // Main
>>> params plist[];
>>> plist = readdata("parameters");
>>> doall(plist);
>>> // Data File "parameters" follows.  Data files listed in it must exist.
>>> // each line is greater than 80 bytes and is only wrapped here by email
>>> // (actual files attached)
>>> x               y               r               b infilename
>>> outfilename
>>> 1               2               1.234           1 inf001.data
>>> outf001.data
>>> 3               4               5.678           0 inf002.data
>>> outf002.data
>>> On 10/10/07 5:23 AM, Ben Clifford wrote:
>>>> Mihael added the below language construct to the language the other
>>>> day.
>>>> This might be useful where the csv_mapper was being used before to
>>>> read in non-file data.
>>>> Its in the SVN.
>>>> There's a new function: readData. It's not an @function, so don't
>>>> use it
>>>> that way because it won't work (it needs to know what variable it
>>>> assigns to, so that it knows how to interpret the contents of the
>>>> file).
>>>> It can read primitive things, arrays of primitive things, structs and
>>>> arrays of structs.
>>>> It can either take a file or a string as a parameter, although I
>>>> recommend the former since it can deal with data dependencies.
>>>> For example usage, see tests/language-behaviour/readData.swift.
>>>> Here's a short preview:
>>>> type circle {
>>>>         int x;
>>>>         int y;
>>>>         float r;
>>>>         string name;
>>>> circle ca[];
>>>> ca = readData("readData.circleArray.in");
>>>> readData.circleArray.in:
>>>> x               y               r               name
>>>> 1               1               5               CircleOne
>>>> 2               2               7               CircleTwo
>>>> It doesn't deal with spaces in strings in the CSV format for now, but
>>>> it's a start.
>>>> Mihael
>>> plain text document attachment (t5g.swift)
>>> type file;
>>> type params {
>>>   int x;
>>>   int y;
>>>   float r;
>>>   boolean b;
>>>   string infilename;
>>>   string outfilename;
>>> // Simulate an app
>>> {      app {          db "pecho:" p.x p.y p.r p.b p.infilename
>>> p.outfilename  @infile @outfile ;
>>> // Main
>>> params plist[];
>>> doall(plist);
>>> plain text document attachment (parameters)
>>> x               y               r               b
>>> infilename      outfilename
>>> 1               2               1.234           1
>>> inf001.data     outf001.data
>>> 3               4               5.678           0
>>> inf002.data     outf002.data
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
