[Swift-devel] readData
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Oct 10 10:12:10 CDT 2007
Thats not what I encountered when I tested (which surprised me).
I will restest and see what confused me (or my code).
- Mike
On 10/10/07 9:31 AM, Mihael Hategan wrote:
> On Wed, 2007-10-10 at 09:00 -0500, Michael Wilde wrote:
>> Mihael, all - readdata() works great, and I think gives Andrew exactly
>> what he asked for.
>> I updated the example parameter-sweep loop to use readdata to grab the
>> multi-column input file.
>> One note: as far as I can tell, you use the conventions the data columns
>> must be exactly 16 characters wide, space separated. Is that correct? (I
>> assume we'll generalize this time permits).
> No. They must be horizontal-whitespace separated. The 16 characters wide
> restriction does not exist. The following is valid:
> a b           c                        d
> 1 2 3 4
> 5             6 7 8
> 9                        10        11		12
>> Here's the new example, Andrew.
>> - Mike
>> type file;
>> // Simulate encapsulating an app's parameters as a struct
>> type params {
>>    int x;
>>    int y;
>>    float r;
>>    boolean b;
>>    string infilename;
>>    string outfilename;
>> // Simulate an app
>> myapp(params p, file infile, file outfile )
>>      app {
>>          db "pecho:" p.x p.y p.r p.b p.infilename p.outfilename  @infile
>> @outfile ;
>> // Loop over the parameter array, calling app in parallel
>> doall(params plist[])
>>    foreach pval,j in plist {
>>      // convert filename string to mapped file reference
>>      file infile <single_file_mapper;file=pval.infilename>;
>>      file outfile <single_file_mapper;file=pval.outfilename>;
>>      // Call the application
>>      myapp(pval,infile, outfile);
>> // Main
>> params plist[];
>> plist = readdata("parameters");
>> doall(plist);
>> // Data File "parameters" follows.  Data files listed in it must exist.
>> // each line is greater than 80 bytes and is only wrapped here by email
>> // (actual files attached)
>> x               y               r               b
>> infilename      outfilename
>> 1               2               1.234           1
>> inf001.data     outf001.data
>> 3               4               5.678           0
>> inf002.data     outf002.data
>> On 10/10/07 5:23 AM, Ben Clifford wrote:
>>> Mihael added the below language construct to the language the other day.
>>> This might be useful where the csv_mapper was being used before to read in
>>> non-file data.
>>> Its in the SVN.
>>> There's a new function: readData. It's not an @function, so don't use it
>>> that way because it won't work (it needs to know what variable it
>>> assigns to, so that it knows how to interpret the contents of the
>>> file).
>>> It can read primitive things, arrays of primitive things, structs and
>>> arrays of structs.
>>> It can either take a file or a string as a parameter, although I
>>> recommend the former since it can deal with data dependencies.
>>> For example usage, see tests/language-behaviour/readData.swift.
>>> Here's a short preview:
>>> type circle {
>>>         int x;
>>>         int y;
>>>         float r;
>>>         string name;
>>> circle ca[];
>>> ca = readData("readData.circleArray.in");
>>> readData.circleArray.in:
>>> x               y               r               name
>>> 1               1               5               CircleOne
>>> 2               2               7               CircleTwo
>>> It doesn't deal with spaces in strings in the CSV format for now, but
>>> it's a start.
>>> Mihael
>> plain text document attachment (t5g.swift)
>> type file;
>> type params {
>>   int x;
>>   int y;
>>   float r;
>>   boolean b;
>>   string infilename;
>>   string outfilename;
>> // Simulate an app
>>     app {
>>         db "pecho:" p.x p.y p.r p.b p.infilename p.outfilename  @infile @outfile ;
>> // Main
>> params plist[];
>> doall(plist);
>> plain text document attachment (parameters)
>> x               y               r               b               infilename      outfilename
>> 1               2               1.234           1               inf001.data     outf001.data
>> 3               4               5.678           0               inf002.data     outf002.data
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
