[Swift-devel] Problem with @extractint?
Yong Zhao yongzh at cs.uchicago.edu
Tue Oct 9 20:09:34 CDT 2007
We had discussions about mapping functions vs mappers too. Essentially
readdata is doing what a mapper (an advanced CSV mapper) should do. I am
not sure whether this is the right direction though, as 'readdata' might
just have been implemented as a specialized karajan function, instead of
being a swift level mapper or mapping function.
So for mapping, there are two choices:
either the type info is passed in to the mapping, which will try to
interprete the values according to the types/member-types passed in.
or the mapping is type agnostic, and extractint, extractstring,
extractdata, whatever is applied to a generic value to get the actual
typed data back. I can see cases where this may not work well.
Yong.
On Tue, 9 Oct 2007, Mihael Hategan wrote:
> On Tue, 2007-10-09 at 13:22 +0000, Ben Clifford wrote:
> > The bit of kml that does the assignment is run in a sequential bit that
> > sets up variables, before any of the parallel stuff happens (that usually
> > consists of procedure calls, and is the part that ends up being evaluated
> > in data dependency order rather than source text order).
> > It makes sense to allow what you want to do, I think.
> There was some discussion about removing the @ sign in front of built-in
> functions. There is no need for the distinction, and, apparently, it
> does cause problems.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
