[Swift-devel] Problem with @extractint?
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Oct  8 09:25:43 CDT 2007
@extractint is behaving unpredictably for me.
In the following script:
type file;
int i;
file f;
(file r1 ) set1 ( ) {
   app { set1 @r1 ; }
file f <"varf.value">;
f = set1();
print("f=", at extractint(f));  // this print works when the next assign
                              // stmt is commented out
// i=@extractint(f); // Program works when you comment out this line,
                   // hangs otherwise
//print("i=",i);
it works if i dont try to assign the value of @extractint to an int but
hangs otherwise.
set1 is:
echo 77777 >$1
Ive tried various other patterns, and some seem to work; I dont know if
I missed a data flow issue here or if @extractint has a problem.
Any advice while I continue to debug this?
