[Swift-devel] Re: passing types and variables in swift
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Fri Oct  5 08:31:17 CDT 2007
The code is here: http://www.ci.uchicago.edu/~nefedova/gen-swift-loops
the relevant piece is toward the end:
First you construct in your shell script the string, in my case it
was the strings $output_files and $outp_files. Then you define swift
arrays and write it into your .swift (or .dtm) file:
cat  >> ./MolDyn.dtm <<EOFF
($outp_files) = GENERATOR (whamfiles, s);
string tout = @strcat ("\1_",s,".out");
file outf[] <fixed_array_mapper;files="$output_files">;
file outfiles[]
<structured_regexp_mapper;source=outf,match="(.*).out", transform=tout>;
string INPUT[];
EOFF
Then you populate the arrays with the values (in my case - the values
are the results from applications):
INPUT[$i] = @strcat("input:","$inp2","_",s);
outfiles [$i] = CHARMM4 ($inp1, whaminp, s1,INPUT[$i] );
EOFF
(you do the above inside the loop in your shell script).
Hope this helps,
NIka
On Oct 5, 2007, at 12:27 AM, Michael Wilde wrote:
> Nika, can you post or send the moldyn code which you generate to
> deal with a similar problem to this?
> I thought you mentioned that it was already online but I cant find it.
> Thanks,
> - Mike
> On 10/4/07 11:53 AM, Ben Clifford wrote:
>> On Thu, 4 Oct 2007, Michael Wilde wrote:
>>> is one way to do this to 'eval' a file containing swift expressions?
>>> Or, to #include them?
>>> This would look like a keyword-based value file
>>> myparms.rho[0]=0.1 mparms.theta[0]=0.2
>>> myparms.rho[1]=0.4 mparms.theta[0]=0.8
>>> myparms.rho[N-1]=0.etc mparms.theta[etc]=0.etc
>>> even if not as clean as extractcsv, it might be both fast and
>>> useful for many
>>> other purposes.
>> you can do that already - generate a swiftscript source file from
>> some other source. nika did something like this (and still does,
>> but to a lesser extent) for moldyn.
