[Swift-devel] Re: passing types and variables in swift
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Oct  4 11:50:07 CDT 2007
the extractcsv function sounds a bit like the value-setting mechanism i
proposed when you started on extractint: set many values from one file.
is one way to do this to 'eval' a file containing swift expressions?
Or, to #include them?
This would look like a keyword-based value file
myparms.rho[0]=0.1 mparms.theta[0]=0.2
myparms.rho[1]=0.4 mparms.theta[0]=0.8
myparms.rho[N-1]=0.etc mparms.theta[etc]=0.etc
even if not as clean as extractcsv, it might be both fast and useful for
many other purposes.
- mike
On 10/4/07 11:38 AM, Mihael Hategan wrote:
> These hacks will bite us in the future.
> On Thu, 2007-10-04 at 15:46 +0000, Ben Clifford wrote:
>> i'd be inclined to grab the csv reading code from the csv mapper and see
>> about making a @extractcsv function. It keeps code using it a little bit
>> more like it would if mappers could support it, which is probably the way
>> things will end up one day.
>> On Thu, 4 Oct 2007, Michael Wilde wrote:
>>> a hacky way to do this is first a loop to read the csv file into an array,
>>> then do a foreach over the array.
>>> i suspect we have the constructs (with @extractint) to do this; not sure if we
>>> can read the CSV into an array-of-structs that we can then foreach() over. But
>>> even if not, this will work using parallel arrays, and probably not be too
>>> unpleasing.
>>> lets try it.
>>> On 10/4/07 10:15 AM, Ben Clifford wrote:
>>>> you're the second person today to talk about reading in values from csv
>>>> files. maybe we should implement this.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
