[Swift-devel] passing types and variables in swift
andrewj at uchicago.edu andrewj at uchicago.edu
Wed Oct 3 15:36:40 CDT 2007
Hello,
  I am wondering about the nature of passing values in to the
variable types in Swift.  In particular, I want to conduct
multiple parameter sweeps by altering the numberical values of
certain parameters I am passing as input into the "apps" I end
up running on the Grid.
Now, before I write out all the swift code the wrong way
assuming things that may not be true, I thought I would get
clarification.
My question has to do with using the convenient mapper system
and putting these numerical and/or string parameters into
place in Swift using something like the csv mapper.
say I have a type:
type RGIparams {
  int a;
  int b
  boolean c;
and atomic function:
(Contour c) Segment (ROI roi, RGIparams rgiP) {
 app {
      SegNEx @roi.image @roi.center rgiP.a rgiP.b rgiP.c;
could I do something like this:
RGIparams RGIinput[] <csv_mapper;file="rgi_runs.txt">;
where rgi_runs would contain say
1,2,true
3,4,false
18,20,true
and so on..so that the parameters are passed into the workflow?
I am trying to configure this workflow to be as modular and
general as possible for ease of experimental alteration.
Andrew
