[Swift-devel] calling rmap
Ben Clifford benc at hawaga.org.uk
Mon Oct 1 05:19:29 CDT 2007
In the AbstractFileMapper subclasses, rmap to my intuition should be
callable with the same filename multiple times; however, there are
implementations like this (from FileSystemArrayMapper)
        public Path rmap(String name) {
                if (name == null || name.equals("")) {
                        return null;
                String index = String.valueOf(count);
                filenames.put(index, name);
                Path p = Path.EMPTY_PATH;
                p = p.addFirst(index, true);
                ++count;
                return p;
which look like they can't be called multiple times for the same filename
without causing additions of multiple array elements mapped to the same
file.
This works because rmap is indeed only called once, during invocation of
the existing() method.
So there's a fairly restrictive set of conditions that seems a bit icky.
For example, here's one rough approximation (I haven't checked them for
being strictly true, but its close enough)
   i) a mapper must expect existing() to be called exactly once.
  ii) a mapper does not have to give correct mappings until after the
      existing() call has been invoked.
 iii) rmap should not be called by anyone except the AbstractFileMapper
      existing() implementation (despite its 'public' prototype)
I find the above three to be unintuitive as I attempt to document how to
use AbstractFileMapper as a superclass of your own mappers.
