[Swift-devel] playing with array closing.
Mihael Hategan hategan at mcs.anl.gov
Tue Nov 20 00:42:35 CST 2007
I'm thinking...
It may be ok to deal with array closing lexically instead of in a
dataflow way. In other words close the array after the last lexical
write (the scoping problem you mention still remains, but seems ok).
This may simplify the implementation and have less memory overhead.
The downside is that some corner cases may still break (e.g. calling
listvals(array) from inside the foreach - though maybe that breaks
anyway).
On Tue, 2007-11-20 at 06:04 +0000, Ben Clifford wrote:
> I spent some time at the weekend and today playing with 'the array closing
> problem'.
> The array-closing problem is what happens when we combine
> single-assignment semantics (which say that you will only write a=foo;
> once for each variable a) with our array assignment semantics (which say
> that arrays are populated by multiple assignments, a[0]=foo; a[1]=bar;).
> Below, exhibit A, is a program which does not work in the present
> trunk implementation - instead it hangs after executing
> top-level statements R,S,T and before executing statement W.
> Statement W will not be executed until the array name 'array' is closed,
> that is, until it is known that there are no further writes to the array.
> So I prototyped some compile-time dataflow analysis (a bit like the
> present input marking code that already exists) to see that statements
> R,S,T write (or potentially write to) 'array' and that no other statements
> do.
> Armed with this knowledge, the compiled karajan code is modified so that:
>  i) when datasets are created (using vdl:new) they are labelled with a
> list of statements that may write to them.
>  ii) those statements are modified so that they notify the appropriate
> datasets when they have finished.
> So each statement issues a partial close on the datasets it writes to, and
> each dataset is aware which partial closes to expect.
> When a dataset has received partial closes (at runtime) from everything it
> is expecting (which is determined at compile time), it becomes fully
> closed.
> In the example code, that means that statement W's dependency on the array
> being closed is now satisfied, and so it is executed, and so this workflow
> ends.
> Its not so straightforward - for example, statement U writes to the array
> several times, and we don't want the first write to do the corresponding
> partial close. So the above processing happens only for statements in the
> same scope as the declaration. In the case of sub-scopes, such as inside a
> foreach, partial closes don't happen, but the enclosing statement (foreach
> in the example below) are treated as a single statement which completes
> and closes only when the whole loop is finished.
> I think this is the right approach to pursue for this problem.
> Also, I think that this implementation could join up with the present
> dataset marking code (which is used to determine what is an input and what
> is not), and also be used for better compile time type checking and
> related things (eg. checking for variables declared multiple times,
> variables assigned to multiple times when they shouldn't be, ...)
> ==== EXHIBIT A, being a program which does not work in the present trunk
> implementation ====
> type file;
> (file f) writefile(int s) {
>   app {
>     echo s stdout=@f;
> (file f) listvals(file array[]) {
>   app {
>     echo @filenames(array) stdout=@f;
> file array[];                    (Q)
> array[0]=writefile(99999);       (R)
> array[1]=writefile(10000);       (S)
> foreach i in [2:5] {             (T)
>   array[i]=writefile(i+80);      (U)
> file out <"out">;                (V)
> out = listvals(array);           (W)
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
