[Swift-devel] Emails from LSF from NCSA tungsten: normal or problem?
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Nov  9 08:47:26 CST 2007
I get tens to hundres of these from tungsten.
I dont see an error here - are these normal and if so can i prevent the
email?
If it indicates an error, what is this telling me?
(the short runtime at th end is suspcicious but other than that I dont
see an error in here)
-------- Original Message --------
Subject: Job 1110502: <#! /bin/sh;#;# LSF batch job script built by
Globus 4.0.1-r3 Job Manager;#;#BSUB -i /dev/null;#BSUB -o
/dev/null;#BSUB -e /dev/null;#BSUB -N;#BSUB -n
1;X509_USER_PROXY=/u/ac/wilde/.globus/job/tund.ncsa.uiuc.edu/21595.1194618548/x509>
Done
Date: Fri, 9 Nov 2007 08:36:10 -0600
To: wilde at ncsa.uiuc.edu
Job <#! /bin/sh;#;# LSF batch job script built by Globus 4.0.1-r3 Job
Manager;#;#BSUB -i /dev/null;#BSUB -o /dev/null;#BSUB -e /dev/null;#BSUB
-N;#BSUB -n
was submitted from host <tund> by user <wilde>.
Job was executed on host(s) <tune224>, in queue <normal>, as user <wilde>.
</u/ac/wilde> was used as the home directory.
</u/ac/wilde> was used as the working directory.
Started at Fri Nov  9 08:35:49 2007
Results reported at Fri Nov  9 08:36:10 2007
Your job looked like:
# LSBATCH: User input
#! /bin/sh
# LSF batch job script built by Globus 4.0.1-r3 Job Manager
#BSUB -i /dev/null
#BSUB -o /dev/null
#BSUB -e /dev/null
#BSUB -N
#BSUB -n 1
X509_USER_PROXY=/u/ac/wilde/.globus/job/tund.ncsa.uiuc.edu/21595.1194618548/x509_up;
export X509_USER_PROXY
GLOBUS_LOCATION=/usr/local/prews-gram-4.0.1-r3/; export GLOBUS_LOCATION
GLOBUS_GRAM_JOB_CONTACT=https://tund.ncsa.uiuc.edu:50031/21595/1194618548/;
export GLOBUS_GRAM_JOB_CONTACT
GLOBUS_GRAM_MYJOB_CONTACT=URLx-nexus://tund.ncsa.uiuc.edu:50032/; export
HOME=/u/ac/wilde; export HOME
LOGNAME=wilde; export LOGNAME
	if test 'X${LD_LIBRARY_PATH}' != 'X'; then
	    LD_LIBRARY_PATH="${LD_LIBRARY_PATH}:"
	else
	    LD_LIBRARY_PATH=""
	fi
	export LD_LIBRARY_PATH
#Change to directory requested by user
cd /scratch/users/wilde/swiftdata/awf8-20071109-0827-it230m61
. /usr/lsf/conf/profile.lsf &&
/usr/lsf/6.0/linux2.4-glibc2.3-x86/bin/lsgrun -p -m "$LSB_HOSTS" /bin/sh
"shared/wrapper.sh" "angle4-ggxk5uji" "-jobdir" "g" "-e"
"/u/ac/wilde/angle/bin/angle4.sh" "-out" "stdout.txt" "-err"
"stderr.txt" "-i" "-d"
"disks/ci-gpfs/angle/spool_1|_output/of/spool_1|_output/cf/spool_1"
"-if" "/disks/ci-gpfs/angle/spool_1/ncdm2-1182355200-dump.1.272.pcap.gz"
"-of"
"_output/of/spool_1/of.ncdm2-1182355200-dump.1.272.angle|_output/cf/spool_1/cf.ncdm2-1182355200-dump.1.272.center"
"-k" "/u/ac/wilde/swift/tools/mystart" "-a"
"disks/ci-gpfs/angle/spool_1/ncdm2-1182355200-dump.1.272.pcap.gz"
"_output/of/spool_1/of.ncdm2-1182355200-dump.1.272.angle"
"_output/cf/spool_1/cf.ncdm2-1182355200-dump.1.272.center"  2> /dev/null
Successfully completed.
Resource usage summary:
     CPU time   :      0.71 sec.
     Max Memory :         3 MB
     Max Swap   :         6 MB
     Max Processes  :         1
     Max Threads    :         1
