[Swift-devel] Re: started angle-1000 using ci-san data and ext	mapper
    Ben Clifford
    benc at hawaga.org.uk
    Wed Nov  7 10:05:25 CST 2007
now that you're running with larger compute jobs, the amount of time spent
in staging as a proportion of the whole runtime is much less.
also, are you running with lazy errors on or off (that is set in the swift
properties). I think off. for the purposes of letting runs continue
longer, that might be a useful setting to turn on.
On Wed, 7 Nov 2007, Michael Wilde wrote:
> > > I'll be as UC in an hour but want to start a test run first.  What should
> > > we
> > > run next?
> > In the absence of a reliable site to run on, not sure what there is to do.
> Im going to run a test on just the data stagein problem: same data but to 1
> job.
> That should help separate the throttle problems from the basic data problems.
