[Swift-devel] Re: started angle-1000 using ci-san data and ext	mapper
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Nov  7 08:52:06 CST 2007
No, have not - am working on it. Let me know if you can help.
Is that error retry change ( 3 => 10) must be a patch, as I dont see a
property for it?
Lets also discuss what options we have for working around the data
transfer problem.
I'd like to propose two test runs:
- data is all local, no gridftp, and data xfer is unthrottled
- job throttle wide open, but job delivery rate slowed down to a GT2
happy-level.
If we have a central job dispatcher that is aware of where data is from
a simple map, want to see if we can then achieve fast runs.
I'll be as UC in an hour but want to start a test run first.  What
should we run next?
On 11/7/07 8:36 AM, Ben Clifford wrote:
> On Wed, 7 Nov 2007, Michael Wilde wrote:
>> Sounds good, will try. With this kind of cluster problem, there's little else
>> we can do from outside the cluster.
> Did you get stuff working on another site yet? Site selection should cause
> better sites to be preferred by magic.
