[Swift-devel] Re: started angle-1000 using ci-san data and ext	mapper
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Nov  7 08:32:24 CST 2007
In IM Ben said:
Ben Clifford
its possible to change swift to retry jobs more than 3 times.
i did that with andrew with it up at 10
sometimes jobs were running 5 times or so
it doesn't fix broken nodes but it increases chances
of workflow completion.
Sounds good, will try. With this kind of cluster problem, there's little
else we can do from outside the cluster.
On 11/7/07 8:13 AM, Ben Clifford wrote:
> On Tue, 6 Nov 2007, Michael Wilde wrote:
>> Ive gotten about 10 failures so far from PBS aborts; looks like a node is bad
>> again (sent mail).
> 713 attempts to run jobs worked, 416 failed.  (that's at the execute2
> level)
> Looks like a combination of file transfer failures and job execution
> failures.
