[Swift-devel] started angle-1000 using ci-san data and ext mapper
Michael Wilde wilde at mcs.anl.gov
Tue Nov 6 23:36:19 CST 2007
started this running at 23:07, ~wilde/angle/data.
processing the files of spool_1 and spool_2 and naming the outputs
accordingly.
I spotted several failures to create a kickstart dir in the prior run
(which i killed) and at least one such error in this run.
Ive gotten about 10 failures so far from PBS aborts; looks like a node
is bad again (sent mail).
Added a zcat to the app to decompress the uic data.
Am using Mihael's ext mapper, and its working great so far.
This is what my *entire* mapper looks like:
#! /bin/sh
awk <angle-spool-1-2 '
BEGIN { server="gsiftp://tp-osg.ci.uchicago.edu//disks/ci-gpfs/angle"; }
{ printf "[%d] %s/%s\n", i++, server, $0 }'
In a next pass this mapper will take as params the spool dir(s) to map,
and will do a find on those dirs.
