[Swift-devel] slow swift startup time
Mihael Hategan hategan at mcs.anl.gov
Mon Nov 5 22:03:44 CST 2007
On Mon, 2007-11-05 at 22:01 -0600, Michael Wilde wrote:
> Like I said when I sent it - I wasnt complaining about it as an error; I
> was wondering if the *fact* that its requesting a lock could be causing
> a delay. (Eg, trying to lock, sleeping, failing, and then continuing).
I guess it depends on the fs. If you want to eliminate the possibility,
run it from a local fs.
> I was just trying to look for an explanation of why startup is slow.
> - Mike
> On 11/5/07 8:45 PM, Mihael Hategan wrote:
> > It's a warning. warning != error.
> > On Mon, 2007-11-05 at 18:56 -0600, Michael Wilde wrote:
> >> The lock error I was referring to is this, on stdout/err:
> >>    Failed to acquire exclusive lock on log file.
> >> Below is the log file text that accompanied it.
> >> Note that Im not complaining about this error - it went away when I
> >> started compiling on terminable again.
> >> Im just pointing it out as a suspect in the slow startup. It surprised
> >> me that we bother to lock the logfile, unless Java is gratuituously doig
> >> it for us.
> >> - Mike
> >> Logfile head showed:
> >> 2007-11-04 10:15:28,949-0600 INFO  Loader awf3.swift: source file is
> >> new. Recompiling.
> >> 2007-11-04 10:15:31,315-0600 INFO  Karajan Validation of XML
> >> intermediate file was successful
> >> 2007-11-04 10:15:34,597-0600 INFO  unknown Using sites file: ./sites.xml
> >> 2007-11-04 10:15:34,599-0600 INFO  unknown Using tc.data: ./tc.data
> >> 2007-11-04 10:15:36,606-0600 INFO  unknown Swift v0.3-dev
> >> libexec/svn-revision: line 1: svn: command not found
> >> 2007-11-04 10:15:36,607-0600 INFO  unknown RunID: 20071104-1015-afgc18i3
> >> 2007-11-04 10:15:36,825-0600 INFO  AbstractDataNode Found data
> >> pcapfiles.$[]/1.[0]
> >> pcapfiles.$[]/2.[1]
> >> pcapfiles.$[]/3.[2]
> >> pcapfiles.$[]/4.[3]
> >> pcapfiles.$[]/5.[4]
> >> 2007-11-04 10:16:26,917-0600 INFO  FlushableLockedFileWriter Could not
> >> acquire lock on /home/wilde/angle/data/./awf3-20071104-1015
> >> -afgc18i3.0.rlog
> >> java.io.IOException: No locks available
> >>          at sun.nio.ch.FileChannelImpl.lock0(Native Method)
> >>          at sun.nio.ch.FileChannelImpl.tryLock(FileChannelImpl.java:804)
> >>          at java.nio.channels.FileChannel.tryLock(FileChannel.java:983)
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.restartLog.FlushableLockedFileWriter.<init>(FlushableLockedFileWriter.java:26)
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.restartLog.RestartLog.create(RestartLog.java:123)
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.restartLog.RestartLog.partialArgumentsEvaluated(RestartLog.java:55)
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.PartialArgumentsContainer.executeChildren(PartialArgumentsContainer.java:51)
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java(Compiled
> >> Code))
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java(Compiled
> >> Code))
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java(Inlined
> >> Compiled Code))
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java(Compiled
> >> Code))
> >>          at
> >> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java(Compiled
> >> Code))
> >>          at
> >> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java(Compiled
> >> Code))
> >>          at
> >> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java(Compiled
> >> Code))
> >>          at
> >> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Inlined
> >> Compiled Code))
> >>          at
> >> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java(Compiled
> >> Code))
> >> 2007-11-04 10:16:26,921-0600 WARN  RestartLog Failed to acquire
> >> 2007-11-04 10:16:26,999-0600 INFO  vdl:execute START thread=0-4 tr=angle4
> >> 2007-11-04 10:16:26,999-0600 INFO  vdl:execute START thread=0-1 tr=angle4
> >> 2007-11-04 10:16:26,999-0600 INFO  vdl:execute START thread=0-5 tr=angle4
> >> 2007-11-04 10:16:27,000-0600 INFO  vdl:execute START thread=0-3 tr=angle4
> >> 2007-11-04 10:16:27,001-0600 INFO  vdl:execute START thread=0-2 tr=angle4
> >> On 11/5/07 6:46 PM, Michael Wilde wrote:
> >>> Im running on tg-login.uc.teragrid.org (IA64) and seeing very long swift
> >>> start times.
> >>> My swift command wrapper prints the wf start and end times with the
> >>> swift stdout sandwiched in between.  Here's an example of those,
> >>> followed by the swift log file. In this run, i start swift in the
> >>> background, then tail the stdout file. it was about 70 seconds (on my
> >>> watch) before swift responded with its initial messages on stdout. (I
> >>> dont think its being buffered, but thats worth checking...)
> >>> Note that swift was launched at 18:30:49 and its logfile entry with the
> >>> runid came at 18:32:05.  32:05-30:49 = 76 seconds!
> >>> This was swift 1456 compiled on terminable (or login, i forget).
> >>> Suspicious: when I was running a version compiled in tg-login under Java
> >>> 1.4 I would get an error message from a Java method trying to lock the
> >>> log file. Not sure if this logging action (which now does not give a
> >>> message) is related to this slow start time.
> >>> - Mike
> >>> UC64$ cat swift.out
> >>> Swift Script local-noks.swift starting at Mon Nov 5 18:30:49 CST 2007
> >>> Swift v0.3-dev r1456
> >>> RunID: 20071105-1831-d7t5l2n3
> >>> angle4 started
> >>> angle4 started
> >>> angle4 started
> >>> angle4 started
> >>> angle4 started
> >>> angle4 completed
> >>> angle4 completed
> >>> angle4 completed
> >>> angle4 completed
> >>> angle4 completed
> >>> Swift Script local-noks.swift ended at Mon Nov 5 18:32:34 CST 2007 with
> >>> exit code 0
> >>> UC64$ head awf*.log
> >>> 2007-11-05 18:31:09,566-0600 INFO  Loader awf6.swift: source file is
> >>> new. Recompiling.
> >>> 2007-11-05 18:31:30,454-0600 INFO  Karajan Validation of XML
> >>> 2007-11-05 18:31:55,465-0600 INFO  unknown Using sites file: ./sites.xml
> >>> 2007-11-05 18:31:55,466-0600 INFO  unknown Using tc.data: ./tc.data
> >>> 2007-11-05 18:32:05,518-0600 INFO  unknown Swift v0.3-dev r1456
> >>> 2007-11-05 18:32:05,520-0600 INFO  unknown RunID: 20071105-1831-d7t5l2n3
> >>> 2007-11-05 18:32:06,701-0600 INFO  AbstractDataNode Found data
> >>> pcapfiles.$[]/1.[0]
> >>> 2007-11-05 18:32:06,702-0600 INFO  AbstractDataNode Found data
> >>> pcapfiles.$[]/2.[1]
> >>> pcapfiles.$[]/3.[2]
> >>> UC64$
> >>> _______________________________________________
> >>> Swift-devel mailing list
> >>> Swift-devel at ci.uchicago.edu
> >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
