[Swift-devel] Kickstart runs on localhost are failing
Mihael Hategan hategan at mcs.anl.gov
Sun Nov 4 21:07:50 CST 2007
On Sun, 2007-11-04 at 19:37 -0600, Michael Wilde wrote:
> I get job exceptions when I run with kickstart on localhost,
> regardless of whether clustered or not.
> The jobs seem to run (3x each) but fail each time. First time gets
> "Application exception: Missing argument jobdir", 2nd & 3rd get
> "Application exception: The cache already contains
> localhost:awf4-20071104-1843-ds8hn11a..."
That probably shouldn't happen unless you're trying to assign to the
same variable twice. Does this work without kickstart?
> Clustered run is in run137, unclustered in run138
> The latter log dir has a file swiftdata.find.out which lists all the
> files in my data dir (has a local/ branch at the top for localhost jobs).
> Error in both cases is below.
> Will try next doing kickstart in both ways via gram.
> - Mike
> 2007-11-04 18:47:40,946-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=angle4-cgqcmmji - Application exception: Missing argument jobdir
> for sys:element(rhost, wfdir, jobid, jobdir)
> 2007-11-04 18:47:41,085-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-2-1194223436415) setting status to Failed
> org.globus.cog.abstraction.impl.file.FileNotFoundException:
> angle4-cgqcmmji-stderr.txt not found.
> 2007-11-04 18:47:41,344-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-2-1194223436424) setting status to Failed
> angle4-cgqcmmji-stdout.txt not found.
> 2007-11-04 18:47:41,503-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=angle4-bgqcmmji - Application exception: Missing argument jobdir
> 2007-11-04 18:47:41,553-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-1-1194223436458) setting status to Failed
> angle4-bgqcmmji-stderr.txt not found.
> 2007-11-04 18:47:41,638-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-1-1194223436467) setting status to Failed
> angle4-bgqcmmji-stdout.txt not found.
> 2007-11-04 18:47:41,882-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=angle4-agqcmmji - Application exception: Missing argument jobdir
> 2007-11-04 18:47:41,987-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-3-1194223436500) setting status to Failed
> angle4-agqcmmji-stderr.txt not found.
> 2007-11-04 18:47:42,047-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-3-1194223436507) setting status to Failed
> angle4-agqcmmji-stdout.txt not found.
> 2007-11-04 18:51:18,439-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=angle4-dgqcmmji - Application exception: The cache already
> contains localhost:awf4-20071104-1843-ds8hn11a/shared/cf0000.angle.
> 2007-11-04 18:51:18,628-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-2-1194223436543) setting status to Failed
> angle4-dgqcmmji-stderr.txt not found.
> 2007-11-04 18:51:18,762-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-2-1194223436550) setting status to Failed
> angle4-dgqcmmji-stdout.txt not found.
> 2007-11-04 18:51:25,976-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=angle4-egqcmmji - Application exception: The cache already
> contains localhost:awf4-20071104-1843-ds8hn11a/shared/of0002.angle.
> 2007-11-04 18:51:26,401-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-1-1194223436585) setting status to Failed
> angle4-egqcmmji-stderr.txt not found.
> 2007-11-04 18:51:26,726-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-1-1194223436592) setting status to Failed
> angle4-egqcmmji-stdout.txt not found.
> 2007-11-04 18:51:28,040-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=angle4-fgqcmmji - Application exception: The cache already
> contains localhost:awf4-20071104-1843-ds8hn11a/shared/cf0001.angle.
> 2007-11-04 18:51:28,492-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-3-1194223436627) setting status to Failed
> angle4-fgqcmmji-stderr.txt not found.
> 2007-11-04 18:51:28,816-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-3-1194223436634) setting status to Failed
> angle4-fgqcmmji-stdout.txt not found.
> 2007-11-04 18:54:44,088-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=angle4-hgqcmmji - Application exception: The cache already
> 2007-11-04 18:54:44,440-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-1-1194223436670) setting status to Failed
> angle4-hgqcmmji-stderr.txt not found.
> 2007-11-04 18:54:44,652-0600 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-1-1194223436677) setting status to Failed
> angle4-hgqcmmji-stdout.txt not found.
> 2007-11-04 18:54:44,741-0600 DEBUG VDL2ExecutionContext Exception in angle4:
>          sys:exception @ vdl-int.k, line: 423
>          at
> org.globus.cog.karajan.workflow.nodes.functions.KException.function(KException.java:29)
> 2007-11-04 18:54:46,190-0600 INFO  ExecutionContext Detailed exception:
>          at
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
