[Swift-devel] Kickstart on Angle vs not?
    Ian Foster
    itf at mcs.anl.gov
    Sat Nov  3 18:26:27 CDT 2007
we use a different mechanbism to retrieve kickstart ouput vs. Log file output, it seems. I'd be interested to understand them.
------Original Message------
Sender: swift-devel-bounces at ci.uchicago.edu
To: swift-devel
To: Benjamin Clifford
Sent: Nov 3, 2007 6:19 PM
Subject: [Swift-devel] Kickstart on Angle vs not?
Ben, whats the current tradeoff on running kickstart for the angle work?
When I last checked with you kickstart still goes to one dir and will
likely cause contention.
I now realize that some of the same data can now be obtained from the
wrapper logs.
Better to avoid kickstart then, or do you intend to work on it this week?
(making no value judgment here - just want your suggestion on most
viable route for Angle...)
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Sent via BlackBerry from T-Mobile
