[Swift-devel] swift-on-ec2
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu May 17 16:31:03 CDT 2007
On Thu, 2007-05-17 at 11:51 -0500, Ioan Raicu wrote:
> If Swift can do it (through an LRM presumably), then Falkon could do it
> as well!
I think Falkon could do it by virtue of the fact that Java can
eventually do it if somebody writes the right bits of code.
Mihael
> This should either be done from Falkon, or from the workspace service
> itself, but not from Swift...
> Ioan
> Tiberiu Stef-Praun wrote:
> > Since there are dependencies in setting up the Falcon-enabled cluster
> > (essentially passing the IP of the headnode to the workers), maybe we
> > can have a Swift workflow that start up the whole EC2 grid shebang
> > Tibi
> > On 5/17/07, Tim Freeman <tfreeman at mcs.anl.gov> wrote:
> >> On Thu, 17 May 2007 11:24:49 -0500
> >> > Through those EC2-specific mechanisms you can push per VM instance
> >> deployment
> >> s/per VM instance deployment/per-VM-instance deployment information/
> >> Tim
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
