[Swift-devel] swift-on-ec2
Ioan Raicu iraicu at cs.uchicago.edu
Wed May 16 11:55:18 CDT 2007
I am just catching up with emails from last night...
Ben Clifford wrote:
> On Tue, 15 May 2007, Kate Keahey wrote:
>> As Ian says, Borja and I were planning to meet with Ioan on Thursday to
>> discuss interaction between Falkon and the workspace service (not
>> necessarily/exclusively in the EC2 context). I don't completely
>> understand the relationship between swift and falkon -- are there
>> specific applications or scenarios that you are trying to target in this
>> exercise?
> By virtue of the fact that they come from pretty much the same group of
> people, they're somewhat fuzzily related - but pretty much swift is
> generating (over the duration of its execution, rather than in one batch)
> a bunch of jobs that need executing (as well, as various things like file
> transfers). As it generates them, it sends them off to be executed. The
> official ways that are 'supported' by Swift are by executing them on the
> local machine and by sending them off through GRAM; however, people can
> plug in whatever they want to do submissions.
> I know less about Falkon because it isn't Swift, but the Falkon side of
> things is pretty much about running a bunch of jobs - it plugs into the
> abovementioned place in Swift so that Swift gives Falkon jobs to run, and
> Falkon runs them (with a goal of Falkon being, presumably, to run it much
> more efficiently than if they were submitted straight through GRAM - it
> seems to do pretty well).
We intentionally made Falkon's interface and semantics as similar as
possible to that of GRAM, so applications that normally used GRAM could
easily change to Falkon.
> There's two things going on with swift - one is about making it
> straightforward to use at the low end of things, so that people can start
> using it easily - for the most part, that isn't interesting in itself; the
> other is about getting it to perform well at the high end of things, which
> is where the fun research is. Using Falkon and using EC2 are both on that
> side of things.
Right!
Falkon is certainly about getting more performance from the same hardware.
EC2 on the other hand is more about a new paradigm of how resources are
acquired.  In the batch-scheduled world, the demand for resources is
usually higher than the supply.  In EC2, its likely that the supply for
resources is higher than the demand.  With that said, it means that with
EC2, it is likely that you could always get more resources now if you
were willing to pay for them... this could have implications on the
resource allocation and management policies that govern when it makes
sense to get more resources and when not to.  Using EC2 might be about
performance, but the really interesting part that I see emerging is a
new model that deviates from the traditional batch-scheduled systems the
Grid community has grown accustomed to.
Ioan
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070516/85a2d070/attachment.html>
