[Swift-devel] MolDyn at Purdue
    Ian Foster
    foster at mcs.anl.gov
    Fri May 11 14:11:51 CDT 2007
One more question: should we be trying the TG-Argonne cluster?
Apparently it is fairly idle?
Veronika Nefedova wrote:
> Interesting...
> Apparently, I did submit the reservation for a big run back on Monday
> (I thought it didn't go through at that time). And it is still in the
> queue..
> tg-login1 nefedova/Falkon_v0.8> showq | grep nefedova
> 995068             nefedova       Idle   286     2:00:00  Mon May  7
> 10:02:28
> 1000628            nefedova       Idle   340     4:00:00  Fri May 11
> 10:41:14
> Nika
> On May 11, 2007, at 10:24 AM, Ioan Raicu wrote:
>> Right, so if we want to get roughly the same execution time of 77
>> minutes, we would need 34*20 = 680 machines for 2 hours, right?  If
>> we halve the machine numbers, we can double the time reservation, right?
>> Let me know if you need help with the Falkon settings!
>> Ioan
>>> Nope, its quite possible. Last week I couldn't submit a single job
>>> for almost a day -- their queue was completely full! The message was
>>> something like 'not accepting new jobs in a queue' - or something
>>> like that. The cluster is ridiculously busy. I could try to submit
>>> today a reservation for , say, 20 molecules...
>>> Nika
>>> On May 11, 2007, at 9:01 AM, Ian Foster wrote:
>>>> It seems unlikely to me that you can't even submit it?
>>>> Sent via BlackBerry from T-Mobile
>>>> -----Original Message-----
>>>> From: Veronika Nefedova <nefedova at mcs.anl.gov>
>>>> Date: Fri, 11 May 2007 08:58:12
>>>> To:Ian Foster <foster at mcs.anl.gov>
>>>> Cc:iraicu at cs.uchicago.edu, swift-devel at ci.uchicago.edu
>>>> Subject: Re: [Swift-devel] MolDyn at Purdue
>>>> I think we had a problem submitting a big reservation to NCSA -
>>>> even a smaller ones were in the queue for more then a week at that
>>>> time. When we did a time estimate on a queue time it said something
>>>> like 'unable to predict' or 'unable to accept'...
>>>> Ioan - do you remember what was the exact problem?
>>>> Nika
>>>> On May 11, 2007, at 8:31 AM, Ian Foster wrote:
>>>> I note that we have stopped running at NCSA and switched to trying
>>>> to run at Purdue. A good thing to try, certainly.
>>>> However, could we not have had a big job in the queue at NCSA all
>>>> this time, also, using Falkon, which would have run by now?
>>>> Ian.
>>>> Ioan Raicu wrote:Great, than we are set, the project is
>>>> configurable at the Falkon startup!
>>>> Ioan
>> Ioan Raicu
>> Ph.D. Student
>> Distributed Systems Laboratory
>> Computer Science Department
>> University of Chicago
>> 1100 E. 58th Street, Ryerson Hall
>> Chicago, IL 60637
>> Email: iraicu at cs.uchicago.edu
>> Web:   http://www.cs.uchicago.edu/~iraicu
>>       http://dsl.cs.uchicago.edu/
   Ian Foster, Director, Computation Institute
Argonne National Laboratory & University of Chicago
Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
      Globus Alliance: www.globus.org.
