[Swift-devel] MolDyn at Purdue
Veronika Nefedova nefedova at mcs.anl.gov
Wed May 9 11:38:23 CDT 2007
we are submitting with swift, to GRAM.
purdue ~$ globus-job-run tg-gatekeeper.purdue.teragrid.org/jobmanager-
pbs /bin/hostname
Please specify a TG project number.
GRAM Job failed because the job failed when the job manager attempted
to run it (error code 17)
While you can specify that for globusrun on a command line - it has
to be a way to specify it somewhere inside swift?
Thanks!
Nika
On May 9, 2007, at 11:23 AM, Ben Clifford wrote:
> are they submitting to GRAM (and thence to PBS) or to PBS via some
> cog pbs
> provider?
> On Wed, 9 May 2007, Veronika Nefedova wrote:
>> Hi,
>> I am wondering if somebody knows where in swift we could specify
>> the project
>> name (allocation) for PBS ? Without that we can't submit to PBS at
>> Purdue...
>> In VDL you'd specify that in 'properties' file.
>> Thanks!
>> Nika
>> Begin forwarded message:
>>> From: "Yuqing Deng" <yuqing.deng at gmail.com>
>>> Date: May 9, 2007 10:21:50 AM CDT
>>> To: "Veronika Nefedova" <nefedova at mcs.anl.gov>
>>> Subject: Re: you allocation at Purdue
>>> Is there a way to specify command line argument to the scheduler
>>> from swift
>>> config files?  I need to use -A account with qsub.  Purdue site
>>> does not
>>> support
>>> default account with pbs.
>>> Yuqing
