[Swift-devel] multiple arguments
Mihael Hategan
hategan at mcs.anl.gov
Fri May 4 10:25:54 CDT 2007
On Fri, 2007-05-04 at 14:48 +0000, Ben Clifford wrote:
> On Fri, 4 May 2007, Ben Clifford wrote:
> > > When it comes to files, the scheme was a little simpler. @filename would
> > > pass the file names of the fringe of a particular data tree. And
> > > @filenames would do the same, but each leaf is a single argument.
> > when used in an app block something like:
> > app {
> > myapp "-in" @filenames(myarray[*]) "-type" "fast";
> > then @filenames needs to be able to return something that gets passed to
> > myapp as multiple parameters, rather than a single parameter with spaces
> > in it.
> > I think (?) that this is hard to do if @filenames returns a single value,
> > from a SwiftScript-theory perspective (though I think in the karajan
> > implementation, @filenames can return as many values as it wants?)
> so perhaps what we should say is
> @filenames(myarray)
> returns an array of strings (so @filenames(myarray) has type string[])
> and then say that the behaviour for string arrays being used in an
> application line is to make each element into its own argument.
Exactly.
