[Swift-devel] arguments to swift
    Veronika  V. Nefedova
    nefedova at mcs.anl.gov
    Tue May  1 15:07:33 CDT 2007
Great, thanks! it worked.
Nika
At 02:55 PM 5/1/2007, Mihael Hategan wrote:
>This is undocumented and unsupported, but:
>@arg("NUM")
>You pass it after the .dtm|.swift name:
>swift x.swift -NUM=5
>On Tue, 2007-05-01 at 14:53 -0500, Veronika V. Nefedova wrote:
> > Hi,
> > I couldn't find info on how to pass the arguments to the swift script. For
> > example, I need to pass an integer, say NUM=5 on the command line when
> I am
> > invoking swift. And inside swift script I'd like to address that variable
> > (is it @arg(NUM) ?)... I tried several variations but none seems to work.
> > Could somebody please point me to the documentation or give me an example
> > on how to do that?
> > This is one of the few syntax that I tried (and it didn't work):
> > inside swift script (how to address it):
> > type file{}
> > int N = @arg(NUM);
> > int range[] = [1:N];
> > foreach i in range {
> > BLA
> > and on the command line - how to specify an argument:
> > swift bla.swift NUM=2
> > Thanks!
> > Nika
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
