[Swift-devel] LQCD mapping
Veronika V. Nefedova nefedova at mcs.anl.gov
Tue May 1 13:25:16 CDT 2007
Ok, I tried using a different mapper. It seems that replacing this line:
file lattice[] <filesys_mapper;prefix="lattice.",create=true>;
with this one:
file lattice[] <simple_mapper;prefix="lattice">;
Works just fine. My workflow has finished without any errors.
Nika
At 10:06 AM 5/1/2007, Veronika V. Nefedova wrote:
>At 10:01 AM 5/1/2007, Ben Clifford wrote:
>>On Tue, 1 May 2007, Yong Zhao wrote:
>> > I see, then maybe you should not use filesys_mapper, can you try
>> > simple_mapper instead?
>>The code in there looks like it does approximately the right stuff
>>filename-wise for arrays.
>>Maybe Nika can try with her workflow - if not, I'll try it later.
>Sure, I can try that
>Nika
>>_______________________________________________
>>Swift-devel mailing list
>>Swift-devel at ci.uchicago.edu
>>http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
