[Swift-devel] LQCD mapping
Ben Clifford benc at hawaga.org.uk
Tue May 1 10:01:25 CDT 2007
On Tue, 1 May 2007, Yong Zhao wrote:
> I see, then maybe you should not use filesys_mapper, can you try
> simple_mapper instead?
The code in there looks like it does approximately the right stuff
filename-wise for arrays.
Maybe Nika can try with her workflow - if not, I'll try it later.
