[Swift-devel] Fwd: Re: globus jobs killed on NCSA's IA64	cluster (mercury)
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Mar 21 11:00:38 CDT 2007
On Wed, 2007-03-21 at 10:51 -0500, Veronika V. Nefedova wrote:
> OK. So if I set this submitThrottle to 1 it will submit jobs one at time
> (and it won't wait for the previous jobs to finish) ?
Yes.
>  What will be an
> indication for swift to go ahead and submit the next jobs (time delay?)?
The fact that the submission of the previous job has been completed (ie,
the job manager has put the job in the queue).
>  If
> thats so - than I think  I am ok.
> Thanks again,
> Nika
> At 10:46 AM 3/21/2007, Mihael Hategan wrote:
> >I think these should be ok. Unfortunately I can't tell you what a
> >solution to "as safe as possible" is because of two things:
> >1. The explanation of why your jobs got killed and the solution they
> >proposed are ambiguous. They don't explain much. So the proposed
> >solution may be insufficient or it may superfluous.
> >2. We don't exactly have submission rate limiters. The closest thing is
> >the submission concurrency limiter. Setting this to 1 should work,
> >because this will ensure that at most one job manager will do the
> >submission dance at a time.
> >Mihael
> >On Wed, 2007-03-21 at 10:37 -0500, Veronika V. Nefedova wrote:
> > > Ok. Hmmm. I am about to submit a large run (50 molecules), which could
> > have
> > > as many as 3500 jobs per tier. I really would like to be sure that I do
> > not
> > > brake TG. I want to play as safe as possible thus I'd like to make sure
> > > that I set all the possible parameters to safeguard the run ?
> > > Thanks,
> > > Nika
> > > At 10:31 AM 3/21/2007, Mihael Hategan wrote:
> > > >On Wed, 2007-03-21 at 10:27 -0500, Veronika V. Nefedova wrote:
> > > > > Hi, Mihael:
> > > > > I have these properties modified in my scheduler.xml file:
> > > > >                  <property name="jobThrottle" value="384"/>
> > > > > <property name="maxSimultaneousJobs" value="384"/>
> > > > > Are you suggesting to add also this inside <scheduler>...</scheduler> :
> > > > > <property name="submitThrottle" value="1"/> ?
> > > > > Do these set parameters guarantee me that:
> > > > > 1. I have no more then 384 jobs in a queue at any time
> > > > > and
> > > > > 2. Jobs are submitted to the queue with at least 1 sec delay
> > > >No. They don't. But they may get you closer to that.
> > > > > (these are the requirements from TG NCSA).
> > > > > Thanks!
> > > > > Nika
> > > > > At 09:18 AM 3/17/2007, Mihael Hategan wrote:
> > > > > >There is no direct rate limiter unfortunately. There is a submit
> > > > > >throttle which tells the number of concurrent submissions. Setting
> > that
> > > > > >to 1 may work.
> > > > > >On Fri, 2007-03-16 at 17:02 -0500, Veronika V. Nefedova wrote:
> > > > > > > Hi, Mihael:
> > > > > > > how do I set this throttling parameter ?
> > > > > > > Thanks,
> > > > > > > Nika
> > > > > > > >Date: Fri, 16 Mar 2007 15:53:57 -0600
> > > > > > > >Subject: Re: globus jobs killed on NCSA's IA64 cluster (mercury)
> > > > > > > >To: nefedova at mcs.anl.gov
> > > > > > > >From: consult at ncsa.uiuc.edu
> > > > > > > >Cc:
> > > > > > > >X-Mailer: Perl5 Mail::Internet v1.74
> > > > > > > >Sender: Nobody <nobody at ncsa.uiuc.edu>
> > > > > > > >X-Null-Tag: 2edd4a9833fa010df5441f1443ff58a9
> > > > > > > >X-NCSA-MailScanner-Information: Please contact
> > help at ncsa.uiuc.edu for
> > > > > > more
> > > > > > > >information, amantadine.ncsa.uiuc.edu
> > > > > > > >X-NCSA-MailScanner: Found to be clean
> > > > > > > >X-Virus-Scanned: by amavisd-new-20030616-p10 (Debian) at
> > > > > > mailgw.mcs.anl.gov
> > > > > > > >FROM: Arnold, Galen
> > > > > > > >(Concerning ticket No. 137212)
> > > > > > > >Veronika,
> > > > > > > >If you can throttle the job submission so that there's more
> > than 1
> > > > second
> > > > > > > >between them, that would probably help us out.
> > > > > > > >-Galen
> > > > > > > >Veronika V. Nefedova <nefedova at mcs.anl.gov> writes:
> > > > > > > > >Hi, Galen:
> > > > > > > > >I was told that I could have 384 jobs in PBS at the same
> > time. By my
> > > > > > > > >estimation I had no more then 136 jobs in the queue. What
> > are other
> > > > > > limits
> > > > > > > > >I should keep in mind ?
> > > > > > > > >Thanks,
> > > > > > > > >Veronika
> > > > > > > > >At 04:31 PM 3/16/2007, consult at ncsa.uiuc.edu wrote:
> > > > > > > > >>FROM: Arnold, Galen
> > > > > > > > >>Veronika,
> > > > > > > > >>We see many sequences in our globus-gatekeeper.log on tg-login1
> > > > > > like this
> > > > > > > > >>Notice: 5: Authenticated globus user:
> > > > > > > > >>/DC=org/DC=doegrids/OU=People/CN=Veronika
> > > > > > > > >>Nefedova 137823
> > > > > > > > >>Notice: 0: GRID_SECURITY_HTTP_BODY_FD=6
> > > > > > > > >>Notice: 5: Requested service: jobmanager-pbs
> > > > > > > > >>Notice: 5: Authorized as local user: nefedova
> > > > > > > > >>Notice: 5: Authorized as local uid: 29202
> > > > > > > > >>Notice: 5:           and local gid: 11467
> > > > > > > > >>Notice: 0: executing
> > > > > > > > >>/usr/local//globus-2.4.3-gcc-r5/libexec/globus-job-manager
> > > > > > > > >>Notice: 0: GRID_SECURITY_CONTEXT_FD=9
> > > > > > > > >>Notice: 0: Child 16725 started
> > > > > > > > >>Nefedova 137823
> > > > > > > > >>Notice: 0: Child 16726 started
> > > > > > > > >>Notice: 6:
> > /usr/local/globus-2.4.3-gcc-r5/sbin/globus-gatekeeper
> > > > > > pid=16769
> > > > > > > > >>starting at Fri Mar 16 09:34:12 2007
> > > > > > > > >>...your DN is also popular in the globus-gatekeeper.log.
> > > > > > > > >>tg-login1:/usr/local/globus-2.4.3-gcc-r5/var # grep
> > 'CN=Veronika
> > > > > > Nefedova'
> > > > > > > > >>globus-gatekeeper.log |wc -l
> > > > > > > > >>   15215
> > > > > > > > >>The large number of connects around the same time:
> > > > > > > > >>  grep --after-context=10 Veronika globus-gatekeeper.log | grep
> > > > > > starting |
> > > > > > > > >> grep
> > > > > > > > >>'Mar 16 09:3' | wc -l
> > > > > > > > >>      65
> > > > > > > > >>Notice: 6:
> > > > > > pid=15872
> > > > > > > > >>starting at Fri Mar 16 09:34:02 2007
> > > > > > > > >>Notice: 6:
> > > > > > pid=16644
> > > > > > > > >>starting at Fri Mar 16 09:34:11 2007
> > > > > > > > >>Notice: 6:
> > > > > > pid=16769
> > > > > > > > >>Notice: 6:
> > > > > > pid=16926
> > > > > > > > >>starting at Fri Mar 16 09:34:14 2007
> > > > > > > > >>...could be overwhelming the gatekeeper on tg-login1.
> > > > > > > > >>-Galen
> > > > > > > > >> >Hi, Dave:
> > > > > > > > >> >Could you please give me a bit more information on what has
> > > > > > happened ?
> > > > > > > > >> >Thanks,
> > > > > > > > >> >Nika
> > > > > > > > >> >At 02:12 PM 3/16/2007, consult at ncsa.uiuc.edu wrote:
> > > > > > > > >> >>FROM: McWilliams, David G
> > > > > > > > >> >>Veronika,
> > > > > > > > >> >>The system administrator had to kill several of your globus
> > > > > > > > processes today
> > > > > > > > >> >>because the load average on the node was over 25. Below
> > is a
> > > > list of
> > > > > > > > >> processes
> > > > > > > > >> >>that were killed. Please let us know if you need help
> > > > > > identifying the
> > > > > > > > >> case of
> > > > > > > > >> >>the problem.
> > > > > > > > >> >>Regards,
> > > > > > > > >> >>Dave McWilliams            (217)
> > > > > > 244-1144          consult at ncsa.uiuc.edu
> > > > > > > > >> >>NCSA Consulting
> > > > > > > > Services    http://www.ncsa.uiuc.edu/UserInfo/Consulting/
> > > > > > > > >> >>nefedova 11084     1  0 09:33 ?        00:00:02
> > > > > > globus-job-manager -conf
> > > > > > > > >> >>/usr/local//globus-2.4.3-gcc-r5/etc/globus-job-manager.conf
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>jobmanager-pbs -machine-type unknown -publish-jobs
> > > > > > > > >> >>nefedova 11165     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11166     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11277     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11295     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11379     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11402     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11480     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11522     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11602     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11668     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11715     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11785     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11813     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11892     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 11948     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12004     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12030     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12133     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12172     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12253     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12256     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12443     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12460     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12504     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12534     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12657     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12668     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12773     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12806     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12892     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 12946     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13023     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13072     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13142     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13233     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13245     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13352     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13379     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13474     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13488     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13618     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13663     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13743     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13820     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13887     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 13952     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14046     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14048     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14172     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14196     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14319     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14366     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14430     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14539     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14572     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14703     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14725     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14832     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 14849     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15009     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15017     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15164     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15165     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15322     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15332     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15526     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15544     1  0 09:33 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15671     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15672     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15787     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15842     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15981     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 15982     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16131     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16132     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16320     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16358     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16553     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16622     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16725     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16726     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16845     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16925     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 16989     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 17095     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 17262     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 17305     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 17375     1  0 09:34 ?        00:00:02
> > > > -type
> > > > > > > > >> pbs_gcc -rdn
> > > > > > > > >> >>nefedova 31347 14172  4 13:35 ?        00:00:00
> > /usr/bin/perl
> > r-sc
> > > > ript
> > > > > > .pl -m
> > > > > > > > >> >>pbs_gcc
> > > > > > > > >> >>-f /tmp/gram_1Drc0X -c poll
> > > > > > > > >> >>nefedova 31349 11295  4 13:35 ?        00:00:00
> > /usr/bin/perl
> > r-sc
> > > > ript
> > > > > > .pl -m
> > > > > > > > >> >>pbs_gcc
> > > > > > > > >> >>-f /tmp/gram_fSWNvt -c poll
> > > > > > > > >> >>nefedova 31352 11522  4 13:35 ?        00:00:00
> > /usr/bin/perl
> > r-sc
> > > > ript
> > > > > > .pl -m
> > > > > > > > >> >>pbs_gcc
> > > > > > > > >> >>-f /tmp/gram_a3whWx -c poll
> > > > > > > > >> >>nefedova 31380 16845  4 13:35 ?        00:00:00
> > /usr/bin/perl
> > r-sc
> > > > ript
> > > > > > .pl -m
> > > > > > > > >> >>pbs_gcc
> > > > > > > > >> >>-f /tmp/gram_zz0JuC -c poll
> > > > > > > > >> >>nefedova 31396 14832  4 13:35 ?        00:00:00
> > /usr/bin/perl
> > r-sc
> > > > ript
> > > > > > .pl -m
> > > > > > > > >> >>pbs_gcc
> > > > > > > > >> >>-f /tmp/gram_5jGFI1 -c poll
> > > > > > > > >> >>nefedova 31512 31347  0 13:35 ?        00:00:00 sh -c
> > > > > > > > >> >>/usr/local/pbs/ia64/bin/qstat -f
> > > > 905629.tg-master.ncsa.teragrid.org
> > > > > > > > >> >>2>/dev/null
> > > > > > > > >> >>nefedova 31546 31512  0 13:35 ?        00:00:00
> > > > > > > > >> >>nefedova 31578 31555  0 13:35 ?        00:00:00
> > > > > > > > >> >>905638.tg-master.ncsa.teragrid.org
> > > > > > > > >> >>nefedova 31629 31560  0 13:35 ?        00:00:00 sh -c
> > > > > > > > >> >>/usr/local/torque-2.1.7/ia64/sbin/pbs_iff
> > > > > > > > >> 15001 3
> > > > > > > > >> >>nefedova 31634 31578  0 13:35 ?        00:00:00 sh -c
> > > > > > > > >> 15001 3
> > > > > > > _______________________________________________
> > > > > > > Swift-devel mailing list
> > > > > > > Swift-devel at ci.uchicago.edu
> > > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
