[Swift-devel] req: int2string
Mihael Hategan hategan at mcs.anl.gov
Tue Mar 20 14:46:47 CDT 2007
Actually wait a second. This would be a dependent mapper. This can't be
done unless the mapper code deals with it.
On Tue, 2007-03-20 at 14:44 -0500, Mihael Hategan wrote:
> @string(i)
> On Tue, 2007-03-20 at 14:42 -0500, Tiberiu Stef-Praun wrote:
> > On 3/20/07, Yong Zhao <yongzh at cs.uchicago.edu> wrote:
> > > you can use a simple mapper
> > > solution<simple_mapper;prefix=i, suffix=".out">;
> > Execution failed:
> >         java.lang.ClassCastException
> > > Yong.
> > > On Tue, 20 Mar 2007, Tiberiu Stef-Praun wrote:
> > > > Would like to do something like this:
> > > >         foreach int i in 0..35 {
> > > >                 file
> > > > solution<regexp_mapper;source=int2string(i),match="(.*)",transform="\1.out">;
> > > >                 solution = invoke($i);
> > > > Reason:
> > > >    I need to control (differentiate) the name of the outputs that are
> > > > being generated in the loop such that they do not overwrite themselves
> > > > when they are staged out.
> > > > Any alternatives ?
> > > > Tibi
> > > > Tiberiu (Tibi) Stef-Praun, PhD
> > > > Research Staff, Computation Institute
> > > > 5640 S. Ellis Ave, #405
> > > > University of Chicago
> > > > http://www-unix.mcs.anl.gov/~tiberius/
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
