[Swift-devel] req: int2string
    Tiberiu Stef-Praun
    tiberius at ci.uchicago.edu
    Tue Mar 20 11:30:49 CDT 2007
Perfect
Thanks
On 3/20/07, Yong Zhao <yongzh at cs.uchicago.edu> wrote:
> It'll generate something in between if it is mapped for an array, but not
> for singletons. so in your case it is just:
> 1.out
> 2.out
> etc
> On Tue, 20 Mar 2007, Tiberiu Stef-Praun wrote:
> > Given that I was about to use it in a loop, I have this uncertainty
> > when the loop is unrolled.
> > <simple_mapper;prefix=i, suffix=".out">;
> > will it generate:
> > 1.1.out
> > 2.2.out
> > or
> > 1.1.out
> > 2.1.out
> > I though the simple_mapper would generate that numeral in between
> > prefix and suffix, at least that is how I experienced it in the BRIC
> > workflow.
> > also, can you use a numeral in place of a string:
> > int i
> > ..<simple_mapper;prefix=i, ...
> > Tibi
> > > you can use a simple mapper
> > > solution<simple_mapper;prefix=i, suffix=".out">;
> > > Yong.
> > > > Would like to do something like this:
> > > >         foreach int i in 0..35 {
> > > >                 file
> > > > solution<regexp_mapper;source=int2string(i),match="(.*)",transform="\1.out">;
> > > >                 solution = invoke($i);
> > > > Reason:
> > > >    I need to control (differentiate) the name of the outputs that are
> > > > being generated in the loop such that they do not overwrite themselves
> > > > when they are staged out.
> > > > Any alternatives ?
> > > > Tibi
> > > > Tiberiu (Tibi) Stef-Praun, PhD
> > > > Research Staff, Computation Institute
> > > > 5640 S. Ellis Ave, #405
> > > > University of Chicago
> > > > http://www-unix.mcs.anl.gov/~tiberius/
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
