[Swift-devel] req: int2string
Tiberiu Stef-Praun tiberius at ci.uchicago.edu
Tue Mar 20 11:23:29 CDT 2007
Given that I was about to use it in a loop, I have this uncertainty
when the loop is unrolled.
<simple_mapper;prefix=i, suffix=".out">;
will it generate:
1.1.out
2.2.out
or
1.1.out
2.1.out
I though the simple_mapper would generate that numeral in between
prefix and suffix, at least that is how I experienced it in the BRIC
workflow.
also, can you use a numeral in place of a string:
int i
..<simple_mapper;prefix=i, ...
Tibi
On 3/20/07, Yong Zhao <yongzh at cs.uchicago.edu> wrote:
> you can use a simple mapper
> solution<simple_mapper;prefix=i, suffix=".out">;
> Yong.
> On Tue, 20 Mar 2007, Tiberiu Stef-Praun wrote:
> > Would like to do something like this:
> >         foreach int i in 0..35 {
> >                 file
> > solution<regexp_mapper;source=int2string(i),match="(.*)",transform="\1.out">;
> >                 solution = invoke($i);
> > Reason:
> >    I need to control (differentiate) the name of the outputs that are
> > being generated in the loop such that they do not overwrite themselves
> > when they are staged out.
> > Any alternatives ?
> > Tibi
> > Tiberiu (Tibi) Stef-Praun, PhD
> > Research Staff, Computation Institute
> > 5640 S. Ellis Ave, #405
> > University of Chicago
> > http://www-unix.mcs.anl.gov/~tiberius/
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
