[Swift-devel] mapper problem or ...?
Mihael Hategan
hategan at mcs.anl.gov
Tue Mar 13 18:41:21 CDT 2007
On Tue, 2007-03-13 at 18:28 -0500, Veronika V. Nefedova wrote:
> Hmmm. So here is how my files are produced (inside double loop over $s and
> $name):
> file $s9prt <"$name.prt">;
> file $s9wham <"$s9.wham">;
> file $s9crd <"$s9.crd">;
> file $s9out <"$s9.out">;
> file $s9done <"$s9donefile">;
> ($s9wham, $s9crd, $s9out, $s9done) = CHARMM3 (standn, gaff_prm, gaff_rft,
> rtf_file_$s, prm_file_$s, psf_file_$s, crd_eq_file_$s, $s9prt, "$ss1",
> "$s1", "$s2", "$s3", "$s4", "$s5", "$s7", "$s8", "$sprt", "$rcut1", "$rcut2");
> so if I change the mapping of the needed output file ($s9wham), everything
> should work?
> file whamfiles_$s[$i] <"$s9.wham">;
That one won't work.
You need to let Swift map whamfiles_$s[] to what it wants. So you can't
map individual items in an array differently.
I believe that you rely on the fact that whamfiles_xzy maps to the same
file names as some other variables. This won't work. You need to use the
same variable. The file names are irrelevant if the program doesn't make
sense for Swift.
So think about it this way: mentally remove all the mapper declarations
from the Swift program. If after that, the program makes sense, then you
should be good to go. If it doesn't then it's likely it won't work.
Remember, mapping is not something that can be used to hack things
because the workflow structure has nothing to do with the mappers and
Swift ignores mappers when figuring out the data flow.
(dependent mappers notwithstanding)
> i=`expr $i + 1`
> and call the function:
> (whamfiles_$s[$i], $s9crd, $s9out, $s9done) = CHARMM3 (standn, gaff_prm,
> gaff_rft, rtf_file_$s, prm_file_$s, psf_file_$s, crd_eq_file_$s, $s9prt,
> "$ss1", "$s1", "$s2", "$s3", "$s4", "$s5", "$s7", "$s8", "$sprt", "$rcut1",
> "$rcut2");
> Nika
> At 06:12 PM 3/13/2007, Mihael Hategan wrote:
> >On Tue, 2007-03-13 at 18:07 -0500, Veronika V. Nefedova wrote:
> > > ok, here is in short what I need to do:
> > > at some point in the workflow N files are produced (in my case its 68, but
> > > it could be any number). These files produced each by a separate job (i.e.
> > > N jobs produce N files).
> > > The next job in the workflow needs to take those N files as an input.
> > > Question: how do I pass these unknown number of files as an input to an
> > > application ? The array_mapper didn't work (or i didn't use it correctly).
> >In this case you need some other kind of mapper that can deal with
> >unknown numbers of items. The default mapper (i.e. specifying no mapper)
> >should work.
> >So you need to do:
> >file whamfiles_002[];
> >foreach v,k in someinput {
> > whamfiles_002[k] = job(v);
> >... = GENERATOR(whamfiles_002);
> > > Thanks!
> > > Nika
> > > At 05:56 PM 3/13/2007, Mihael Hategan wrote:
> > > >On a third thought. This looks like, eventually, you are trying to do
> > > >the same thing that Yong did with the dependent mappers earlier. I think
> > > >he would have more insight on the topic.
> > > >On Tue, 2007-03-13 at 17:23 -0500, Veronika V. Nefedova wrote:
> > > > > I think I am confused. Sorry!
> > > > > what will be the type of 'whamfiles' ? If its a string - will the swift
> > > > > know to brake it down to filenames and stage them all in ?
> > > > > Also - is there a mapper (or whatever) that can map the list of
> > *logical*
> > > > > file names to an array ? (thats what I was trying to do).
> > > > > Thanks!
> > > > > Nika
> > > > > At 04:54 PM 3/13/2007, Mihael Hategan wrote:
> > > > > >Oh my :)
> > > > > >@whamfiles_m002 is known by the system at all times. That means
> > > > > >GENERATOR does not need to wait for the actual files to be there since
> > > > > >it knows very well what @whamfiles_m002 is (the list of names).
> > > > > >You should try this instead:
> > > > > >... GENERATOR(whamfiles, str) {
> > > > > > app {
> > > > > > generator @whamfiles, str;
> > > > > >... = GENERATOR(whamfiles_m002, "m002")
> > > > > >Mihael
> > > > > >On Tue, 2007-03-13 at 16:46 -0500, Veronika V. Nefedova wrote:
> > > > > > > Hi,
> > > > > > > I have a question:
> > > > > > > I am using a fixed_array_mapper to pass some 68 files as an
> > input to my
> > > > > > > application called GENERATOR. I need to use the mapper since the
> > > > number of
> > > > > > > input files is unknown before the workflow starts. Here is how I
> > > > use it:
> > > > > > > file whamfiles_m002[] <fixed_array_mapper;files="
> > > > solv_chg_a0_m002_wham,
> > > > > > > solv_chg_a1_m002_wham, solv_chg_a10_m002_wham, <snip -- many
> > files,
> > > > you
> > > > > > get
> > > > > > > the idea>, solv_repu_0_0DOT2_b1_m002_wham">;
> > > > > > > These files are all generated by stage four of my workflow, each
> > > > file is
> > > > > > > mapped to a physical filename, for example:
> > > > > > > file solv_chg_a0_m002_wham <"solv_chg_a0_m002.wham">;
> > > > > > > and this particular file is produced this way:
> > > > > > > (solv_chg_a0_m002_wham, solv_chg_a0_m002_crd, solv_chg_a0_m002_out,
> > > > > > > solv_chg_a0_m002_done) = CHARMM2 (standn, gaff_prm, gaff_rft,
> > > > > > > rtf_file_m002, prm_file_m002, psf_file_m002, crd_eq_file_m002,
> > > > > > > solv_chg_a0_m002_prt, "prtfile:solv_chg_a0", "system:solv_m002",
> > > > > > > "stitle:m002", "rtffile:parm03_gaff_all.rtf",
> > > > > > > "paramfile:parm03_gaffnb_all.prm", "gaff:m002_am1", "stage:chg",
> > > > > > > "urandseed:5395098", "dirname:solv_chg_a0_m002");
> > > > > > > Then I call my application (the last stage of my workflow,
> > stage five)
> > > > > > > (solv_chg_m002, solv_disp_m002, solv_repu_0DOT2_0DOT3_m002DOTwham,
> > > > > > > solv_repu_0DOT3_0DOT4_m002DOTwham,
> > solv_repu_0DOT4_0DOT5_m002DOTwham,
> > > > > > > solv_repu_0DOT5_0DOT6_m002DOTwham,
> > solv_repu_0DOT6_0DOT7_m002DOTwham,
> > > > > > > solv_repu_0DOT7_0DOT8_m002DOTwham,
> > solv_repu_0DOT8_0DOT9_m002DOTwham,
> > > > > > > solv_repu_0DOT9_1_m002DOTwham, solv_repu_0_0DOT2_m002DOTwham ) =
> > > > GENERATOR
> > > > > > > (@whamfiles_m002, "m002");
> > > > > > > And then when I start my workflow, the GENERATOR starts right
> > away.
> > > > I am
> > > > > > > not sure why. Does the mapper look for the physical files on the
> > > > disk and
> > > > > > > when finds them - starts right away ? I do have the needed
> > files in the
> > > > > > > directory from my previous runs. Or there is something else wrong
> > > > here ?
> > > > > > > 109] wiggum /sandbox/ydeng/alamines > Swift V 0.0405
> > > > > > > RunID: b0n2liektep92
> > > > > > > pre_ch started <---------- thats the first stage
> > > > > > > generator_cat started <----------- not supposed to start now!
> > > > > > > My complete dtm file is in /home/nefedova/swift.dtm on
> > > > > > > terminable.ci.uchicago, but its pretty big...
> > > > > > > Thanks,
> > > > > > > Nika
> > > > > > > _______________________________________________
> > > > > > > Swift-devel mailing list
> > > > > > > Swift-devel at ci.uchicago.edu
> > > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
