[Swift-devel] dot error
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Mar  9 15:31:05 CST 2007
Identify from ImageMagick quickly eats up all the memory when I try to
run it on that file.
I'm tempted to conclude that something might be broken with dot.
Can you try producing a PostScript file instead?
Mihael
On Fri, 2007-03-09 at 15:31 -0600, Veronika V. Nefedova wrote:
> Nope!
> [nefedova at evitable ~]$ dot -ograph_big.png -Tpng
> swift-MolDyn-free-01dqgqzbhns11.dot
> [nefedova at evitable ~]$ cp graph_big.png public_html/
> [nefedova at evitable ~]$ which dot
> /usr/bin/dot
> At 03:25 PM 3/9/2007, Mihael Hategan wrote:
> >Did dot complain about anything?
> >On Fri, 2007-03-09 at 14:55 -0600, Veronika V. Nefedova wrote:
> > > Hi,
> > > Not sure what happened -- but I was unable to produce (or display) the
> > > correct png file out of dot file that was generated by swift (after the
> > > workflow was done).
> > > I put my dot file on evitable in
> > ~nefedova/swift-MolDyn-free-01dqgqzbhns11.dot
> > > Then I ran the dot command to generate the png file:
> > > $dot -ograph_big.png -Tpng swift-MolDyn-free-01dqgqzbhns11.dot
> > > Then I tried to display it in the browser and got this:
> > > The image "http://www.ci.uchicago.edu/~nefedova/graph_big.png" cannot be
> > > displayed, because it contains errors.
> > > Any idea what is wrong here?
> > > Thanks,
> > > Nika
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
